Where to Rebuild?
Old Feb 25, 2011 | 09:34 AM
rhart's Avatar
Because race car…
Default Where to Rebuild?
I want to boost my KA the right way and although I know the best way is to not boost it @ all, I also know that some steps like freshening the motor are a must.
Currently my 12X,XXX KA has the usual valve seal puffing smoke issue from a stop light. ANd I'm tired of it. I'm sure it could use some additional TLC as well.
With that being said, where would you guys suggest I get a rebuild done? I've mentioned it before but the build wont be for crazy power...in the 250-300hp range or whatever I can get on 10 -12psi and stock 370cc SR injector and a tune. I know this will vary some. Either way, streetable power, not track power.
I'm in Clearwater. I would bring a longblock to a shop to get the work done...just wanting to get pointed in the right direction.
Thanks,
-Royce
If it has tires or boobs it's going to cost you money...
Old Feb 25, 2011 | 02:22 PM
mewantkouki's Avatar
no
Originally Posted by rhart
I want to boost my KA the right way and although I know the best way is to not boost it @ all - WRONG
I also know that some steps like freshening the motor are a must. - NOT NECESSARILY
Currently my 12X,XXX KA has the usual valve seal puffing smoke issue from a stop light. ANd I'm tired of it. I'm sure it could use some additional TLC as well. - CHANGE YOUR VALVE STEM SEALS
With that being said, where would you guys suggest I get a rebuild done? IN YOUR GARAGE
I've mentioned it before but the build wont be for crazy power...in the 250-300hp range or whatever I can get on 10 -12psi and stock 370cc SR injector and a tune. I know this will vary some. Either way, streetable power, not track power. - A KA IN GOOD SHAPE WILL HANDLE 350 WHP WITH NO SWEAT. USE 555CC INJECTORS IF YOU CAN FIND THEM.
I'm in Clearwater. I would bring a longblock to a shop to get the work done...just wanting to get pointed in the right direction. UNITED SPEED WORLD CAN HANDLE THE MACHINE WORK IF YOU INSIST ON HAVING YOUR MOTOR REBUILT. I'D LOOK INTO ASSEMBLING IT YOURSELF FIRST THOUGH. THERE ARE SEVERAL FAQ'S AND HOW TO VIDEOS AVAILABLE. IT ISN'T ROCKET SCIENCE.
Thanks,
-Royce
Join KA-T.org
Old Feb 25, 2011 | 07:14 PM
rhart's Avatar
Because race car…
The KA was never designed to be boosted, like the SR and RB series engines and with the regularity that I see drift punks and complete idiots popping the KA and contributing to their shitty reputation I want to make something that the average KA owner could aspire too. I dont want to ham fist together a KA only to have it blow up in a months time. Thats why I asked where I could get a rebuild done. Think insurance.
I have been a member of KA-T.org for while(since '09) and recognize it as a good source of info though there are time it seems dated.
I worry that my KA is not in good shape and would fall victim to broken ring lands (replacing the pistons with forged ones is my plan) or something I may over look.
Why 555cc injectors? IIRC those are RX-7 injectors right?
I thank you very much for the advise on United Speed World. Recognize its not rocket science, but also that there are experts that do this sort of thing regularly and they might be better at the process than I am.
-Royce
Old Feb 25, 2011 | 09:12 PM
Anthony R's Avatar
SAL-T
740cc's, rom-tune, retard timing, z32 maf, forged pistons, headstuds, headgasket, stock bearings, replace tensioner's, stem seals, should really be it
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Old Feb 26, 2011 | 05:08 AM
asia989's Avatar
Why So Serious?
go talk to martin, he'll build you something bulletproof
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old Feb 26, 2011 | 04:48 PM
no
Ka's run stock timing on rom tunes. You don't have to retard anything. Connecting rods are also proven to be the weakest link past 350whp too, unlike melt happy SR20's.
Old Feb 26, 2011 | 05:15 PM
chome's Avatar
Will sleep for food.
Going on almost two years now. Stock motor, stock cooling, but I was as baller as Kevin.
Old Feb 26, 2011 | 05:42 PM
TNathe's Avatar
this, i would say Engine Lab (where mine was done), but I have heard several people question the quality that has come out of their facility and I am second guessing them as well since the last time I was in my motor and what I saw. I would def consult with martin if I ever rebuilt.
dippincrx
May 9, 2007 09:49 AM
technoracer
Dec 13, 2006 11:40 AM
HAVIK
Nissan/Infiniti Tech
7
Apr 20, 2004 01:44 PM
str33tracer_18
Mar 26, 2004 03:08 AM
