LS Rebuild....
Old Dec 12, 2006 | 08:34 AM
technoracer's Avatar
Gone honda again.....
Default LS Rebuild....
i am getting brand new LS i-beam rods. and gonna get gsr pistons. standard bore. other than rings and bearings what do i need to know about doing this? and could it be done in a weekend? also can i do it with the motor still in the car? and what does FTW mean?Fu@k The World?
Old Dec 12, 2006 | 08:36 AM
uyht's Avatar
ftw == for the win
ftl == for the lose
--Its all good--
Old Dec 12, 2006 | 08:50 AM
Lookin2GoFA$T's Avatar
Team 'Petersburg Puller
at least your sig is funny
__________________________________________
www.floridasportsman.com
Originally Posted by P057
"Wow I had a hard time understanding that... but from what I gather you found an open-box item that wasn't cheaper. You bought it anyways. You then called someone a dumbass while making fun of their misfortune of losing a job as you were leaving the store?
I'm surprised you were able to get out the store with that big "SUCKER" sign affixed to your back.
Old Dec 12, 2006 | 12:30 PM
what kinda machine work will i need to do, if i want stock bore. i need the block honed right? then i can put in the pistons and rods. and put it back together. im gonna be doing all this while the motor is in the car. how hard is it going to be?
Old Dec 12, 2006 | 02:51 PM
civicized's Avatar
Default in car rebuild
it's possible to rebuild in the car, but it is a sloppy, emergency sort of way to go about it, particularly when honing. Keeping everything clean and doing any needed measurements and the like, makes it not worth it.
Old Dec 12, 2006 | 03:04 PM
99B16Si's Avatar
+1
Also if you are using factory ls rods there will have to be machining done to either the small end of the rod or the pistons for them to work together. if your looking to bump up your compression and want to avoid the machine work look for some pr3 or p30 pistons
Old Dec 12, 2006 | 03:54 PM
isaacvela06's Avatar
Cronic Masterbater
on gsr pistons to ls rods you need to shave off 1mm inside the piston on each side for them to fit g/l with the build
Old Dec 12, 2006 | 06:33 PM
luvsracin87's Avatar
turbo hhhmmmm?
i did my rebuild in the car(rings and rod bearings) in 1 1/2days(had to wait for the head to be resufaced)
Steve: (813) 810.4146 <~ call or text
Old Dec 12, 2006 | 06:59 PM
juiced2ndgenteg's Avatar
If you are getting brand new forged pistons and rods, you will most likely only need the block honed and the crank micropolished. You may need the block decked if the mating surface of the head is damaged.
Old Dec 12, 2006 | 07:01 PM
lilmike13's Avatar
SAVE THE SOHC!
amen
93 del sol si (project)
88 honda cvic ef (daily driver)
hit me up on fb ( www.facebook.com/stewartracing13 )
TR "Old Skool EF" Member #166
