SR20det idle problem. Please help!!!!!!!!!!
I think he had it dyno tuned. Not 100% positive though.
Jun, did you take into consideration your Power FC has that problem and don't save your tune? I know you had all the settings written down could there possibly have been a short somewhere in the FC. Just a thought. Also this is a faily recent problem I remember Cole telling me about it and how he loaned you his iacv so you could see if that would fix the problem. I don't get it that car ran like a champ while I was up there.
<3 no homo lol
yeah, that could be causing all kinds of problems. No offense, but if you have ruled out operator error and it really is just "forgetting" then there might be "holes" in the tune where it has dumped the data and it only shows up as a problem at certain times.
Its a bit of a long shot, but it is possible.
Might be the pump causing problems. walboro's do that. try a different pump.
again, its a bit of a long shot, but it is possible that, that is the key to the whole thing.
either a different pump or a fuel gauge to see what's going on.
Ok I'm going to check for vacuum leaks first. Then Ill go to the pump, then get a new tune. The car was tuned on the power fc, but it still did the same thing when I had a safc2 on it, so thats why I narrowed out the tuner as the problem. Thankyou guys for all your help! I really appreciate it.
cagedeyecam
Nissan/Infiniti Tech
5
Oct 26, 2010 03:52 PM
