SR lagging at WOT...?
Old Apr 8, 2010 | 03:42 PM
  #81 (permalink)
elitist's Avatar
TR Balla Donor Supreme
turbo vibrating? If it doesn't have shaft play bolts could be loose holding it on or gasket between turbo/manifold could be blown
Old Apr 8, 2010 | 03:45 PM
  #82 (permalink)
bearback's Avatar
nearly undead
yea, i watch my clamp on the elbow vibrate when the noise came, and stopped when the noise stopped. and my turbo does have shaft play, but it did when i installed it as well(but its probly gotten worse, especially running oil only, no..?). and i just replaced that gasket, and the 5 bolt gasket.
live to love the RWD.
89 seafoam coupe w/ SR20 and more- FOR SALE<- click
FAX
Originally Posted by Shadytrixta1
lulwhat? where? custom gutted? didnt know that was a mod unless of course we're talking vtec!
Originally Posted by sean1
if it has tits or wheels its gonna cost lots of money
______________________________
Old Apr 8, 2010 | 09:27 PM
  #83 (permalink)
Z28ricer's Avatar
Doesnt see what you did
www.nissanusa.com
I hear you can buy a vehicle from them that isnt broken, and then take it to them when it does break, so that you can stay your retarded ass away from the hood release lever.
Old Apr 9, 2010 | 05:12 AM
  #84 (permalink)
4wheeldriftS13's Avatar
February - Ride of the Month
Originally Posted by bearback
and who know anything about a turbo vibrating...?
You are never passing tech. Ever. I will make sure of it. Your car will blow up and ruin everyone's day with having to clean the oily mess your car is going to make
dude I hate to admit, but your are fucking clueless.
RIP Tim Aldrich
Old Apr 9, 2010 | 05:49 AM
  #85 (permalink)
LongFellow's Avatar
Please hold...
Why do I have a feeling your missing the main ground on the motor, or some other important ground.
Team White Car 2010
Old Apr 9, 2010 | 09:13 AM
  #86 (permalink)
sean1's Avatar
i has double turbo
You should seriously just take it to somebody who knows wtf their doing
my honda sounds like a lawnmower, because it is one.
Old Apr 9, 2010 | 10:40 AM
  #87 (permalink)
bearback's Avatar
nearly undead
what the fuck............... seriously... i am not stupid, i will pass tech, and i have all grounds, wires, nick nacks, and scally wags in the right place. im pretty sure that diveder from the screamer pipe vibrated loose, and thats whats rattling around when the wastegate opens... i have 0 leaks, maybe a little water from my turbo water feed thats capped off, but its cool, ive got no antifreeze in my shit.
thanks for your help and support, faggots!
FAX
Old Apr 9, 2010 | 06:07 PM
  #88 (permalink)
greenman100's Avatar
Your mechanical timing is wrong
Your ignition timing is wrong
Your fuel pump has low voltage
Your fuel pump is wired off some other circuit not intended for powering the pump
Your water cooled turbo isnt watercooled
You aren't running antifreeze, which means your water pump isnt getting lubrication and your cooling system has no corrosion protection
You have some mystery turbo noise you are unable to diagnose
honestly, it is shocking your car moves under its own power at all.
Old Apr 10, 2010 | 05:51 AM
  #89 (permalink)
^"but guys im not stupid"
RIP Tim Aldrich
Old Apr 10, 2010 | 07:17 AM
  #90 (permalink)
Super Coupe's Avatar
Old school TR member
BOOM BOOM POWWWWWWWWWw
Get to work let us know when you figure it out.
Has this motor ever run correctly?
