SR lagging at WOT...?
Old Apr 10, 2010 | 07:45 AM
  #91 (permalink)
mewantkouki's Avatar
no
^ No, but it pulls "hard as fuck" sometimes.
Old Apr 11, 2010 | 11:40 AM
  #92 (permalink)
WhiteNgold's Avatar
is underwater
OK... U dont ned the colored links.
start by taking valve cover off.
remove timing chain shield.
remove timing chain tensioner.
remove intake cam gear.
remove cylinder 1 (closest to u) spark plug
Put crank on top dead center (carefully) (second mark from left on crank)
make sure piston is at tdc by looking in the hole
set exhaust cam to appropriate position per diagram (minimal chain slack between crank and cam gear)
set intake cam to appropriate position per diagram (minimal chain slack between gears)
tighten back down the gear (dont forget this)
install tensioner
count links between the little circles on gears (20)
set cas and make sure the indicator is pointing to the correct dot
install cas
install timing chain shield
install valvecover
tighten to specs on EVERYTHING
make sure everything is grounded
install spark plug
start car and adjust ELECTRONIC timing thru cas after it has reached normal operating temp
add COOLANT
Old Apr 11, 2010 | 10:17 PM
  #93 (permalink)
bearback's Avatar
nearly undead
^thanks dude, but idk why this is going on still... yes, i need coolant, but im broke as shit, so thats a no for now, turbo is holding strong, engine runs like a champ at 14* btdc(im guessing, because its very close to the 15* mark, but the cas is maxed out clockwise) BUT, it idles at 13-1400 with the iacv all the way shut........ and suggestions?
live to love the RWD.
89 seafoam coupe w/ SR20 and more- FOR SALE<- click
FAX
Originally Posted by Shadytrixta1
lulwhat? where? custom gutted? didnt know that was a mod unless of course we're talking vtec!
Originally Posted by sean1
if it has tits or wheels its gonna cost lots of money
______________________________
Old Apr 12, 2010 | 05:37 AM
  #94 (permalink)
WhiteNgold's Avatar
is underwater
what is ur vaccum at? a healthy/in time motor should be at -20psi. if u are 100% positive that u have no boost leaks and its not at -20, then ur timing is wrong. if u are positive ur timing chain and gears are spot on, then re install the cas. to be positive.... take the valvecover off to see the markings on the cas. i would also suspect coolant temp sensor. ive seen some weird shit happen with bad temp sensor. lmk
Old Apr 12, 2010 | 05:44 AM
  #95 (permalink)
WhiteNgold's Avatar
is underwater
u should have left the iacv alone. just saying because once u have everything correct, that should be in the perfect spot. just one less thing to mess with ya know. is it running rich or lean or hard to start?
Old Apr 12, 2010 | 10:11 AM
  #96 (permalink)
greenman100's Avatar
Originally Posted by greenman100
Your mechanical timing is wrong
Your ignition timing is wrong
Your fuel pump has low voltage
Your fuel pump is wired off some other circuit not intended for powering the pump
Your water cooled turbo isnt watercooled
You aren't running antifreeze, which means your water pump isnt getting lubrication and your cooling system has no corrosion protection
You have some mystery turbo noise you are unable to diagnose
Add vacuum leak(s) to the above list.
Old Apr 12, 2010 | 10:23 AM
  #97 (permalink)
NeedCAforS13's Avatar
TOTALLY AWESOME.
And now he's selling the motor. Notice zero mention of all the problems he's having with it...
https://www.tamparacing.com/forums/n...swap-sale.html
Sketchy as hell man.
(O=O/-ROUGH WORLD-\O=O)
Old Apr 13, 2010 | 05:47 AM
  #98 (permalink)
WhiteNgold's Avatar
is underwater
to OP,
dont sell the swap cuz u cant get it running right. if uve got anything to trade, ill make the drive and help/fix it for ya. shared_pm me if intersted
Old Apr 13, 2010 | 12:19 PM
  #99 (permalink)
bearback's Avatar
nearly undead
ok, im not selling this because im having "problems", im selling because theres something else i want, but its sort of a pipe dream sorta thing, but well see.....
and whitengold- yes, -20 at idle. and if youre in sarasota, id be more than willing to drive down to you. im in bradenton until tomorrow afternoon, so lmk!
FAX
Old Apr 13, 2010 | 12:55 PM
  #100 (permalink)
TOTALLY AWESOME.
bullshit.
