how easy is the 2jzgte to work with? compared to a KA24DET
KA wiring is fkn cake. i hope youre not serious. and y do you hate sr? you could take the money you will be putting into a 2j or rb, vq is outta the question if ka wiring is hard for you, and build a really reliable and fast sr. or just build your KA into KA-T the right way and be baller. if you really want reliablitily, and power do an LSX. 2j is not the way for you, and rb wiring is going to make you re-think your religion if you thought ka is tough. take it to a shop, or do an easy swap.
ok here is the deal ,if you gonna buy everything pre fab you gonna spend an arm and a leg.............check this out
jdm 2jzgte motor set $1800-$2200 make sure comes with third ecu plug (body harness plug) igniter and uncut harness
r154 tranny 1988-1992 supra turbo $400-$800
1jz gte bellhousing $330 from champion toyota in texas
you need to do this upgrades to the tranny
forged first gear trusth washer $70 from marling crawling
reinforced bearing carrier $70 from marling crawling
mounts,shifter extension and drive shaft $1500 from www.tech2motorsport.com
usdm spec water pump $200
sr20det koyo rad $275
flex a lite dual fans $220
1jzgte or 7mgte clutch kit $400-$800
1jzgte flywheel $200-$400
intercooler buy a good one no ebay shit $600- $1000
turbo piping $200-$300
blow off valve (tial or synapse) $175-$300
wire harness plug an play $450 from tech2motorsport
fuel pump they recomend using at least a walbro pump $100
misc.
seals ,fluids ,hoses,timing belt, clutch slave ,clutch slave braided hose,2 dakota
interface boxes(need this to make the rpm and odometer work) ,couplings ,turbo clamps etc $ 500
This is what I can think of right now ,hope it helps. oh and for the timing in the 2jz is easy just stay away fron the vvti 2jz versio 91998 and up
check my build
https://www.tamparacing.com/forums/t...-progress.html
misc.
check my build
here is the complete list from their site
Please find below my detailed description of every part needed to do a 2JZ-GTE with stock turbos swap into a Nissan 240SX. Please note that parts prices may vary or may not be necessary for your specific build so adjust accordingly.
Description---------------------------------------------------Cost
2JZ-GTE Motorset--------------------------------------$2,500.00
Tech2Motorsports - 240SX/2JZ Swap Kit-----------$1,500.00
Tech2Motorsports - Intercooler Kit------------------$650.00
Tech2Motorsports - Extended Shifter Kit------------$250.00
Tech2Motorsports - Clutch Line Kit--------------------$120.00
Tech2Motorsports - Throttle Cable Bracket----------$45.00
Tech2Motorsports - Down Pipe Adapter--------------$100.00
Tech2Motorsports - Misc. Hose Kit---------------------$275.00
Tech2Motorsports - Radiator----------------------------$450.00
Tech2Motorsports - Motul Oil Kit-----------------------$234.36
Tech2Motorsports - Serpentine belt--------------------$30.00
Tech2Motorsports - OEM Toyota 1JZ Bellhousing----$375.00
Tech2Motorsports - OEM Toyota 1JZ Flywheel-------$275.00
Tech2Motorsports - Pulley Kit---------------------------$135.00
Tech2Motorsports - Pilot Bearing-----------------------$22.00
Tech2Motorsports - Plug n Play Harness--------------$450.00
Tech2Motorsports - Speedometer 8K Magnetic Pick-Up Coil -$30.00
Tech2Motorsports - Speedometer Signal Interface---$80.00
Tech2Motorsports - Tachometer Signal Interface-----$80.00
Tech2Motorsports - Clutch & Pressure Plate-----------$850.00
Titan Motorsports - Greddy Oil Filter Relocation Kit--$135.00
Titan Motorsports - OEM Toyota Oil Filter-------------$15.00
Titan Motorsports - NGK Iridium Plugs-----------------$42.59
Titan Motorsports - OEM Toyota Water Pump--------$127.34
Titan Motorsports - OEM Toyota Timing Belt---------$21.00
Marlin Crawler - MC-10075, Heavy Duty Bearing Cover---$45.00
Marlin Crawler - MC-10077, Heavy Duty Shifter Seat-$10.00
Marlin Crawler - MC-10078, Shifter Socket-------------$6.00
MKIII Short Shifter------------------------------------------$175.00
ARP Flywheel Bolts-----------------------------------------$45.00
First Gear Thrust Washer----------------------------------$35.00
Limited Slip Differential-------------------------------------$600.00
R-154 Transmission-----------------------------------------$500.00
3 Inch Exhaust-----------------------------------------------$500.00
Battery relocation Kit---------------------------------------$85.00
MKIII Slave Cylinder----------------------------------------$45.00
Downpipe----------------------------------------------------$250.00
Twin Fal Fans-----------------------------------------------$250.00
Walbro 255 LPH Fuel Pump -------------------------------$89.50
Misc. Other Parts, Just in case Funds------------------$400.00
GRAND TOTAL------------------------------------------$11,827.79
S
