my 2jz onto 240 little progress
Old Dec 24, 2008 | 03:22 PM
BABILLARACING's Avatar
Default my 2jz onto 240 little progress update 3-18-09
Hi I am getting the parts to do a 2jz swap onto my s14
here are some pictures of what I have done so far, not much but I am in not hurry
here what I got so far
turbonetics hp-72 96 a/r ball bearing
aeromotive a1000 fuel pump and regulator with 100 micron fuel pump with 8an feed and 6an return
tial bov
1jz bellhousing
r154 tranny reinforced with first gear trusth washer and bearing carrier both parts from marlin crawler also extended shifter everything made by me
yonaka racing intercooler
misc parts
parts I have but not picture
act hd clutch kit
starter
water pump
slave clutch and braided line
koyo radiator
fal dual fans
synapse wastegate
need
motor set ( I will buy this last)
turbo manifold
mounts (I will fabricate this myself)
harness (is done on paper)
misc hoses
water pump pulley
driveshaft
flywheel I need to know hom much the stock one weights ?
Thanks for looking any comments or advice will be appreciatted
Thanks....................Omar
Old Dec 25, 2008 | 08:32 AM
kbprice's Avatar
Rocket Scientist
What are you going to do for engine management? You're going to run out of fuel really quick with that turbo above about 14-15psi. Especially if you use a JDM engine with 440cc injectors. Just an observation. Looks like it's going to be a cool build though.
'96 Supra NA-T
"I'm not driving fast, I'm flying low..."
Old Dec 25, 2008 | 09:01 AM
thanks for the advice but I will get it running stock and afterwar i will use a microtech with 800 cc siemens injectors .and the big turbo.Omar
Old Dec 30, 2008 | 03:13 PM
tranny closed and ready , now getting some money to get the motor set
Old Dec 30, 2008 | 09:13 PM
2mtx12's Avatar
nice looking good
Old Dec 31, 2008 | 08:40 AM
thanks man
Old Dec 31, 2008 | 11:07 AM
UserName's Avatar
Beardlife.net
I have 6 brand new precision 780cc injectors for $300 if you're in the market. They should be good for 650hp maybe a little more. Good luck with you're project. It gonna be a beast when its done!
Old Dec 31, 2008 | 11:30 AM
thanks man , I definetly let you know when I am ready , and are they are hold and peak or saturated? top feed or side feed? Thanks............Omar
Old Jan 1, 2009 | 05:42 PM
Toyota Terrorist's Avatar
RSP Hardtopper
I have a na motor and auto trans you can have for 500. Comes with harness and ecu. It's still in the car for a test drive as well. 117k miles no smoke or ticks.
Horsepower is like sex, You never have enough.
Originally Posted by gsr corey
i have a bmx and you can ride on the bars
Originally Posted by B18C14
How about you sell me the seat then you can sit on the post and ride back home...
Old Jan 2, 2009 | 09:17 AM
I let you know...........good deal..................thanks Omar
