i need somone who knows SR's up and down
Old Feb 9, 2009 | 05:48 PM
  #21 (permalink)
Blackzenki82's Avatar
(OO\____/OO)
Originally Posted by sean1
and he uses a volt meter to check sensors..thats a first for tr lol
i TRY to do things right.... being the first time i've ever really worked on motors like this...
i'm used to old 302s 351s..... not these "high tech" engines... so i try and do what has to be done and not cut too many corners...
epstein, thanks for all your help man, out of all the forums i've posted this on, your replys are by far the most informative and detailed....
Originally Posted by Epstein
The sensor changes resistance based on temp. Unplug the sensor and measure the resistance across it (car should be off). It should be 2.1k-2.9k when the engine is cold, and about 300-330 ohms when it's at operating temp. Basically, it should be between those numbers. When they go bad you'll either get an open or short circuit.
now... when i test, should i have the key to the "on" position? this is my first time delving into the eletronic elements of a motor...
hell, if my buddy who let me use his multimeter hadn't set it to the "20" for the voltage testing, i wouldn't know what to do with it.... all the numbers, and what not lol... so lend me a hand here, and once again, thanks!!!
Old Feb 9, 2009 | 05:56 PM
  #22 (permalink)
Epstein's Avatar
Retired
No prob. It sounds like you know your way around an engine, and that's a big help!
Old Feb 9, 2009 | 06:06 PM
  #23 (permalink)
Anthony R's Avatar
SAL-T
throwing it up i the air. check coil packs one could be messed up i had something similiar happen to me and swapped out coil packs and it was good to go. jus an idea g/l
Matthew "RudeBoy" Nugent 2/03/88-04/01/09
Old Feb 9, 2009 | 06:21 PM
  #24 (permalink)
(OO\____/OO)
already hit em up with a multimeter, and checked out fine, i also have two extra coil packs and tried each on every cyl... starter was doing work son....
what "ohm" reading do i check on the multimeter Ep? i know it's the upside down horseshoe looking thing... for testing do i set it at 2000k 200k 20k 20 2000 or 20??
i'm also having another potential issue.... i used my after cat o2 sensor from my KA and used it in the elbow on my SR... they looked exactly the same, and had the same connector... while running, if i disconnect it, it does absolutely nothing, no change.... let me know if i'm doing anything wrong here lolol
once again guys, thanks for all your input and HALPZ!!
Old Feb 9, 2009 | 06:35 PM
  #25 (permalink)
JaxS13Racer's Avatar
Sold my sol for Silvia
for the ohmmeter set it to 20k for the cold temp and 2000 for the operating temp. When you are checking resistance always go for the setting that is just above what you are aiming for other wise you will end up blowing the fuse in the meter or frying the meter if it is not fused, or you could invest in an auto ranging one, they cost a little more but are well worth it.
Old Feb 9, 2009 | 06:37 PM
  #26 (permalink)
RobRobking18's Avatar
call me puppy
u can use a multimeter to check sensors for resistance...
Old Feb 9, 2009 | 07:04 PM
  #27 (permalink)
(OO\____/OO)
okay let me make sure this is right...
20k on the ohm setting....
here's the numbers cold.... with the engine off...
here's the only part of the CTS plug that gave me any reading... this is right right? (no it's not the TPS plug..)
here's the reading i got with the egine running at operating temp....
on either side of the three wire plug, i didn't get ANY reading at all... so i'm assuming those are the power/ground, and the middle is the signal....
let me know if i'm doing anything wrong guys, and once again, thanks for the help!!!
Old Feb 9, 2009 | 07:09 PM
  #28 (permalink)
(OO\____/OO)
oh wait, lemme go check it on the 2000 at operating lolol....
Old Feb 9, 2009 | 07:17 PM
  #29 (permalink)
(OO\____/OO)
here it is @ 2000 at operating temp..... averages at 205/206
correct????
Old Feb 9, 2009 | 07:56 PM
  #30 (permalink)
SR20 Freak's Avatar
your on the right plug but you cant test ressistance with the harness still connected and with your leads set up like that you are actually testing resistance to ground rather thatn resistance through the ect.
Heres what you need to do:
1. (With cold engine) Disconect the harness plug and on the lower plug (going down under the intake manifold) put your black lead on one of the pins and the red on another with your meter on the 20k setting. i cant remember which two pin go to the ect bu just try them until you get a reading.
2. Reconnect the plug and warm the engine
3. repeat step one with meter on the 2000 scale
