when fans are turned on, water gauge goes crazy
the fans are deffenetly pulling air threw my radiator. I have them mounted inside the engine bay and they pull 1,800 CFM per fan threw may rad, It blows you hair back standing by one of my fenders lol. Maybe the water pump is Shitty? or is it one of those situations were its either crap or not crap with no in between. I should really invest in a after market rad and a nismo therm. I always seem to loose rad fluid also, but to my knowledge my radiator is not leaking. it happens when i dog on the car, I park is and like I noticed one time that I had a puddle of water under my car when I drove away later. In general it looses water some how also, but when parked on a hill and filled properly it still stays at 190-210 degrese. Sorry, really stupid problem, million situations for a fix. heating issues on a car really blow because theirs like a thousand scenarios.
because you mentioned you have had coolant under the car before. while your out get a piece of cardboard thats big enuff to go from tire to tire, bumper to fire wall. when you get where ever you are going place it under the car. I know it sounds stupid. but this way you can see if there is any fluid coming from your car and not someone elses prior to you parking.
IMHO instead of busting your balls on some of these rad. check out the yashimoto's. (sp?) they are cheaper than the fludyne (sp?) as well they come w/ fans sometimes. so you can sell those off to someone else. also you dont have to get a nismo thermostat. either go get one from nissan or go to autozone or something like that and get one there. just be sure to get something that is oem spec "170" I've been running one of those duralast thermostats w/ no issues.
try that and see if it helps.
now its steak and eggs time. i <3 breakfast.
~skott
TR Wondering WTH I moved from FL Member.
Back Then: A stupid Question was one that wasn't asked.
Today: A stupid question is one that wasn't Googled / Ixquicked first.
just another form of parasitic drag and yes they do can go bad too.
edited and fixored.
put it this way. clutch fan, on a typical sr on the dyno, youre talking maaaaaybe a 2 hp. loss.
same car with a taurus single electrical fan, wired through relays, cost nearly 10hp. i have dyno charts to prove it somewhere on my computer at home.
theres a reason these cars come with clutch fans. its the best way to do it.
why do you also think some of the most well built schassis cars in the counrty still use clutch fans? and japan as well?
sure, some people use electrical fans with success, but one will never find its way onto my perfectly cool, even when being beaten on car.
I've had bubbles that didn't come out for days. I was driving home one night then all of the sudden, my needle started to tweak. got home and bleed out some air like I had just filled it up.
Pesky heater core bubbles
dude mishimoto is the next radiator ima run, i have nothing at all against em, i love em, i have a HUGE griffin right now so i dont need it but i am going to get one, that bitch is like 175 (half of a koyo lol) and is the same thing...i agree completely
thanks, Im going to just replace the water pump, put a 170 degree thermostate in and flush the system prior to that and pu the clutch fan on and take fans off possibly...I would like to hear more of a debate about clutch fan verse electric when it comes to horsepower loss or gain.
