when fans are turned on, water gauge goes crazy
Old Mar 26, 2008 | 04:53 PM
Speed cat's Avatar
speed cat
Default when fans are turned on, water gauge goes crazy
When i flip my switch to turn my aftermarket fans on(2 12") It spikes my temp up 10-15 degreese. Also today the fucking thing at idle was like jumping all over the place from 300 back down to 200 like extreamly fast and random. When i started going it was fine and went back to 200-210.
Old Mar 26, 2008 | 04:59 PM
93LowBody's Avatar
TR Balla Donor Supreme
Sounds like air in the system. or a bad sensor.
Old Mar 26, 2008 | 05:20 PM
presidential's Avatar
OG Join Date: 6-15-00
Or, you wired the fans backwards.
1973 VW Squareback
1979 AMC Jeep Cherokee Chief
RIP Tim
Old Mar 26, 2008 | 05:48 PM
Speed cat's Avatar
speed cat
please explain how I wired the fans backwards. Which I had a supiscion I did.
Old Mar 26, 2008 | 06:06 PM
93LowBody's Avatar
They would blow the wrong way but i dont think that would cause that problem.
Old Mar 26, 2008 | 06:25 PM
Um, I really don't think I can answer this question right now in a serious manor but I will do my best.
If the fan is blowing towards the front of the car when it's on, you're doing it wrong. Check the wires from the fan and reverse them.
1973 VW Squareback
RIP Tim
Old Mar 26, 2008 | 06:26 PM
osama tim laden's Avatar
kings cannot fall.
soooooooooo
a fan that should be pulling cold air through a radiator, that is now blowing hot air back at the radiator doesnt sound like a possible problem?
dude, your tech posts are usually wayyyy off.
if you dont know, you dont have to post anything.
or, just stay in the amc forum.
Old Mar 26, 2008 | 06:29 PM
kings cannot fall.
and also.....
Old Mar 26, 2008 | 06:33 PM
Originally Posted by paul kersey
soooooooooo
Technically, it wouldn't be blowing hot air back through the radiator, it would just be causing a massive restriction at speed, nearly blocking it.
1973 VW Squareback
RIP Tim
Old Mar 26, 2008 | 06:50 PM
93LowBody's Avatar
soooooooooo
It could cause the 10-15 degree spike yes. but no way in hell it would cause the temp to bounce from 300-200 and back. if the coolant is really at 300 he has some serious problems.
And show me were my tech posts are way off.
