Datsun Dreaming
I'll give you a shout when I get my car running again. I think Sean said you have a Z32 maf plug tail for him that he's supposed to give to me so I can pick that up too.
Team White Car 2010
Team White Car 2010
I actually have the turbo side for the SS line, I need the banjo fitting for the block side, and I'm hoping that works. If not I ATP sells an -4an to -3an fitting adapter I can use.
I would need an S14 restricted banjo bolt (turbo side) if I used the OEM line. I wanted to use the stock line but trying to find that banjo bolt is way to much work.
Basically I have each side but for different lines. I have the turbo side for the SS line and the block side for the OEM line. which doesnt help at all haha.
Team White Car 2010
Team White Car 2010
At least bavarian autosport makes them for the e30, we have ones that either clip onto the vents or have to screw into the plastic somewhere >_>
