Brake bushing replacement?
Old Apr 9, 2005 | 10:31 AM
SILVIA-S14's Avatar
Suck A Turd!
Default Brake bushing replacement?
Hi All,
My brake bushing tore up so my brake lights are on all the time. I been removing the fuse for time being. I have the new bushing to put in but the area is so congested that i cant seem to find a good angle to get in to push the bushing in place.
I took out the seat and all to make life easier but still no luck. I lubed the bushing as well. I just cant seem to find a way in there and be able to put enough force on bushing for it go thru the hole like it should?
Any ideas?
Rinku
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Apr 9, 2005 | 01:26 PM
SILVIA-S14's Avatar
Suck A Turd!
http://www.imagestation.com/picture/...5/f486fa22.jpg
The 5 highlighted bolts? That's what i am referring to to undo the brake pedal assembly altogether from the firewall and thus have enough slack afterwards to be able to put the bushing in.
http://www.imagestation.com/album/pi...6116809&idx=43
http://web.tampabay.rr.com/hsaini/PI...akebushing.jpg
One of the pics above should work
Thanks
RINKU
FOR SALE ITEMS
Old Apr 9, 2005 | 01:30 PM
proimport's Avatar
There is no easy way to do it but to make it a little easier you can replace the stopper with a bolt and nut. They are easier to get into the cramped space because dont have to push the bushing in you can just hold the bolt in and tighten the nut
Loyalty above all else except HONOR
Old Apr 9, 2005 | 03:11 PM
SILVIA-S14's Avatar
Suck A Turd!
Unbolted the switch, found a flat headed bolt and put that thru the hole...put the switch back it against it at specs such that when brake is depressed swithc is free and not touching the bolt hence the brakes are lit. Once you let go, the bolts flat head hits the switch and viola its off.......bolt is about an inch long so it won't come out on its own......i tried putting a nut on it but turns out after fiddling with it for a while, i didn't really need to as the play is only 1/4 inch and bolt is 1 inch long or so.....so it won't come out on its own.......
Thanks for your help......I post the pic of the bolt i used.....
Rinku
FOR SALE ITEMS
Old Apr 9, 2005 | 03:27 PM
SILVIA-S14's Avatar
Suck A Turd!
http://web.tampabay.rr.com/hsaini/PI...bushing002.jpg
http://web.tampabay.rr.com/hsaini/PI...bushing004.jpg
Thanks
RINKU
FOR SALE ITEMS
Old Apr 9, 2005 | 05:34 PM
cyanide's Avatar
i just went to advance auto, bought one of those various rubber plug packages, and used one from that. works like a champ
Old Apr 11, 2005 | 06:27 AM
Rob.M's Avatar
Down Shift Magazine
I knew if you sat and played with it for a bit you would solve it yourself. Good job Rinky!
Old Apr 11, 2005 | 05:38 PM
SILVIA-S14's Avatar
Suck A Turd!
hehehe... ....thanks Stinky!
FOR SALE ITEMS
accord95
Mar 20, 2004 04:58 AM
RedBaron
Jan 1, 2004 07:22 PM
Matt Vassallo
Nissan/Infiniti Tech
27
Aug 13, 2003 10:26 PM
lstepnio
Subaru Tech
10
Jul 22, 2003 03:19 PM
Ffej207
Jun 21, 2002 05:51 AM
