280zx brake upgrade?
Old Feb 17, 2005 | 01:33 PM
launch's Avatar
You'll need it!!!
Jeff I just like picking on you. I quess you failed to pick up on that.
Launch It Like It's Unbreakable!!!
Old Feb 17, 2005 | 01:38 PM
Epstein's Avatar
Retired
Let's act like grown men, here.
Pads and/or rotors won't make the car stop faster, but they will fight brake fade. Look for something that has a higher operating temp. Not sure if Hawk makes pads for your app, but reading about their line-up is educational.
Resistance to boiling usually increases with the higher numbered DOT fluid. If you grabbed any old bottle, it's probably DOT 3. Try a name branded 4 or 5.
Old Feb 17, 2005 | 02:20 PM
Miles's Avatar
It's a wooden pickle.
i believe all you need to put some z32 whatsits on there is some custom brackets (which shouldn't be horribly expensive to fab up)
Old Feb 17, 2005 | 04:33 PM
  #17 (permalink)
AnTman86T's Avatar
S130 love
Powestop sells crossdrilled rotors which are damn pricey if you wanted to go that route. I would suggest you get Brembo replacement rotors as well as some Metal Master Pads all around. (I have both and they work great)
Old Feb 17, 2005 | 06:32 PM
  #18 (permalink)
StinkyZ's Avatar
Just get some good rotors and some Metal Master pads like Ant said. That should hold you over for a while. Also make sure you do a good job bleeding your brakes with some decent fluid. By the way you can get cross drilled powerstops for $50 a piece.
Left rotor Right rotor
PcarFan
Dec 3, 2003 02:32 PM
flubyux2
Subaru Tech
Nov 27, 2003 09:47 AM
Cronic
Nissan/Infiniti Tech
Jul 17, 2003 04:19 AM
Matt Vassallo
6
Mar 1, 2003 10:13 PM
