The project that never ends...
Old May 12, 2011 | 10:46 AM
  #81 (permalink)
cjackson2802's Avatar
fuel, spark, compression. if it has all those, starts and then dies, check pcv valve and vaccum lines, maf connection etc. you get the idea.
Old May 12, 2011 | 01:57 PM
  #82 (permalink)
Romeyo07's Avatar
I'm thinking something might have rattled lose. Reason being? Apparently my front motor mount wasn't really completely bolted in. The bolt is there but the nut is only on the end.
Old May 13, 2011 | 05:39 AM
  #83 (permalink)
lol did you get it running? just got my girlfriend's gst running last night. had no spark. crank sensor ended up being bad. didnt have time to mess with it so i threw in my spare 1g cam sensor and wired it in. runs great
Old May 14, 2011 | 08:38 AM
  #84 (permalink)
Romeyo07's Avatar
So I charged the battery, made sure all my connections were properly together, turned it over and it wanted to start...like I got SOME combustion but then it would fall on it's face. It did it a few times, then I just stopped. I haven't adjusted a thing, either.
Old May 14, 2011 | 04:17 PM
  #85 (permalink)
wishiwasfast's Avatar
Your probobly not getting spark on all 4. Have you swapped out the coilpack, or power transistor?
Originally Posted by RednekBubba
Just do the normal German torque spec "gudntite"
Originally Posted by 98EclipseTurbo
I have all of the rockers loose on my Intake cam and I believe the timing belt skipped and bent some valves when the harmonic balancer grinded into the valve cover.
Old May 14, 2011 | 06:44 PM
  #86 (permalink)
omgosh's Avatar
Sounds like CAS or some other ignition related component..
Old May 15, 2011 | 08:05 AM
  #87 (permalink)
Romeyo07's Avatar
I have a spare coil pack I can try out. Is there a way to check the power transistor? omgosh - I'm thinking the same thing for some reason but not sure how I can try to fix this myself. Any pointers?
Old May 15, 2011 | 09:35 AM
  #88 (permalink)
omgosh's Avatar
Well ya gotta start with the basic three...fuel spark and air...
Easiest way to verify the first two is try to crank if a few times. Then pull a plug out and smell it for gas...it might be a little wet also..hook it up to the wire and try to crank it again to see if there is spark. No spark on all 4 = bad transistor(uncommon), no crank/cam signal etc. No spark on a pair of cylinders would likely be the coils, or maybe power transistor. Individual cyls would be bad wire, plug.
What year is your car/motor again?
Also you did check all the fuses...right?? lol its probably something stupid related to what you did recently..
Old May 15, 2011 | 11:27 AM
  #89 (permalink)
Romeyo07's Avatar
97 gsx with a mickey mouse 6 bolt 2.3 stroker swap. I decided to name my car Minnie
I checked the fuses, all good. I'll try the things you mentioned. Update to come soon.
On a side note: my 4 year old was "helping" me today cleaning the car. As I pulled the liner off the sunroof shade, he said "daddy why is it covered in cheetos crumbs".
Old May 25, 2011 | 05:51 AM
  #90 (permalink)
Romeyo07's Avatar
So someone wants to trade me the injectors I need and an Evo ecu for my talon shell. Trading works great for me since money doesn't have to be exchanged and I end up getting two big parts out of the way before I get it tuned (not to mention freeing up valuable garage space).
I know we discussed my tuning options before and I was all about the DSM link, but would the Evo ecu suffice?
