Help!! Temp Guage Reading Hot!!
Old Jun 28, 2007 | 09:51 AM
  #41 (permalink)
BeigeTsi's Avatar
Paul Walker
Originally Posted by AnthrAxNSB
But, I wasn't talking sh*t. All I did was offer suggestions.
It's fixed...horray.
Corry man you crack me up
“It’s amusing to find that the road to success is never convenient however the road to failure all most always is...”
-S. Charles
"Excuses are monuments of nothing built by tools of inequity and those who use those tools will be masters of nothing"
-Unknown
"Time is a luxury that even the richest man cant buy"
-Unknown
1990 Talon TSi AWD
Joshua P.
Old Jun 29, 2007 | 03:18 PM
  #42 (permalink)
GsT Racer's Avatar
back in a 4g63
im sure if it did turn out to be something like a head gasket blown or something like that, a new motor wouldnt be a total waste, IF he planned on doing it already. i'm kinda that way too, i need something to break before i upgrade it. for example, my water pump is taking a dump right now, so when i get the water pump replaced, as well as all the timing components, PLUS the cam seals, and while the cam seals are being replaced im getting 272/272 cams. a mod i was probably going to wait until mid-2008 to do, is going to be done in august.
another example, im in mid-process of getting the gm-maft setup, but to install it im going to need straighter i/c piping. so im going to run short-route piping into a brand new intercooler i want to get, all because im getting a gm-maf.
with the new cams and gm-maft, ive already bought a new eprom ecu and im saving to get dsmlink so i can tune everything nicely.
i'd get a 6-bolt motor too, i just dont have the money and/or the reason to get one yet.
oh and ask cory where you can go to have your timing belt fixed. the shop does good work but you would have to get rid of power steering and a/c, and also turn your idle all the way up for the car to run, BUT you would have timing belt replaced
Old Jun 29, 2007 | 07:10 PM
  #43 (permalink)
AnthrAxNSB's Avatar
first
Dirty...
An alternative would be to bring it to me (or whomever), because thanks to the unmentioned shop f*cking my timing up some years back, I've now a heap of experience with replacing timing belts on 4g63 motors.
Old Jun 29, 2007 | 07:15 PM
  #44 (permalink)
GsT Racer's Avatar
back in a 4g63
Dirty...
but hey your car runs good now. mine is running good now too! my idle was so bad because the tps to afc wiring was messed up, and then the afc to ecu wiring was also messed up. runs pretty nicely.
Old Jun 29, 2007 | 07:23 PM
  #45 (permalink)
AnthrAxNSB's Avatar
first
That's good.
Old Jul 1, 2007 | 06:30 PM
  #46 (permalink)
98_GstEclipse's Avatar
Im gonna take out a loan and do a 6-bolt swap and build it. I was at a party Sat night and some people I havent seen in like 2 years were there and saw the car I had and started talking about the kid that owned it before me and how bad he beat on it and how they all beat on it. So I want a fresh motor with no problems....Hopefully
Old Jul 1, 2007 | 06:43 PM
  #47 (permalink)
JR.'s Avatar
JR.
dude there is no such thing as a fresh motor with no problems , do u not see fucking brandnew evos with problems. u will always have problems with a dsm
u can drop a fully built motor in ur car and u will still have problems.
what so hard to understand if u wanna go fast ur going to have problems
98 talon awd automagic
Old Jul 1, 2007 | 07:16 PM
  #48 (permalink)
Im know im gonna have problems. But alot less problems than the motor I have now. The motor I have now has been beat to shit. Everytime I fix one thing another thing will break. And its stupid shit. I just wanna start fresh
Old Jul 1, 2007 | 07:34 PM
  #49 (permalink)
JR.'s Avatar
JR.
dude my motor has been beating to and it still runing strong, i suggest doing a compression test and a leakdown test before u swap it, if everything is fine i dont see the need to swap in another motor.
edit: my motor also has low compression on 1 cylinder and it still runing strong.
Old Jul 1, 2007 | 07:38 PM
  #50 (permalink)
When I push it my motor takes a shit at around 4500rpm and loses power. With the mods I have it should not be running how it is. How many miles are on your motor?
