Another questoin
Old Dec 17, 2005 | 11:52 AM
  #31 (permalink)
CrypticApathy's Avatar
OH SNAP!
didnt he say it up a couple posts?
Old Dec 17, 2005 | 12:09 PM
  #32 (permalink)
Rotary7's Avatar
Get Down-Or-Stay Down
Originally Posted by CrypticApathy
I think the wiper problem is a fuse
The wiper only has 1 fuse,for all of the speeds of the switch.Low/Med/High
So if it works on low,but not on high.Its the switch problem.
and the way you describes it,Shows it.Unless you described it wrong.
My wipers only work on low i think i blew a fuse or something but im to lazy to check the fuses to find out.
Do you want to be tazed?
Old Dec 17, 2005 | 01:27 PM
  #33 (permalink)
OH SNAP!
all i know is it was broken and when i replaced all the fuses it worked again.
Old Dec 18, 2005 | 06:00 PM
  #34 (permalink)
knives's Avatar
TR Balla Donor Supreme
Originally Posted by willjs7
purge controll valve= PCV valve, like i said
rep points u owe me
PCV valve = positive crankcase ventilation valve
I will still give you rep points for effort
Still having the other problems and it's really starting to piss me off
TR's resident A&P mechanic
I make a passive income from the comfort of my home, visit my blog, I would love to show you how to do the same
ISE Automotive-Mobile Mechanic and 24-7 Roadside assistance services from oil changes to full track car builds we do it all and get it done right the first time
Old Dec 18, 2005 | 09:54 PM
  #35 (permalink)
HondaCRX's Avatar
Vtec what?
damn from one problem to the next you always seem to have problems with car! lol well wish you the best of luck even know you fucked me over, and dont want to be friends, but whatever!
Aim: Hondacrxls
Old Dec 19, 2005 | 04:58 AM
  #36 (permalink)
willjs7's Avatar
whoda thunk it? lol my bad
Andrew-
www.autoliftplus.com
Your neighborhood do-it-yourself auto shop!
Old Dec 19, 2005 | 10:05 AM
  #37 (permalink)
FC3Cturbo's Avatar
eats babies
go to rx7club and give IceMark a pm, he fixes wiper/headlight switches for ALOT cheaper than what it would cost to get a new one.
Old Dec 19, 2005 | 03:54 PM
  #38 (permalink)
OH SNAP!
im going to see if i can do it, worse come to worse ill need to replace it.
Old Dec 19, 2005 | 09:00 PM
  #39 (permalink)
knives's Avatar
well the smoking problem seened to fix it self so the only problem I am having is, It bogs down at 3500 rpms but smooths back out at 6000 while it bogs it backfires big time and let out a nice sized puff of smoke?
Old Dec 20, 2005 | 09:33 AM
  #40 (permalink)
OH SNAP!
When you notice the bogging down is it during the first few minutes of driving it or is it a constant thing?
The dreaded 3800 RPM hesitation is cause 90% of the time by poor ground connections between the engine, the battery, and the car. Clean or replace all the under hood ground connections. On 86 model year cars , replacing/regrounding the pressure sensor's ground wire has helped (do not re-ground a 87 or later model year). If there is still a problem after that, look at cleaning the fuel injectors and (on a N/A) that your 5th/6th ports are operating correctly.
I took that off the RX7club forum
