Another questoin
Originally Posted by CrypticApathy
When you notice the bogging down is it during the first few minutes of driving it or is it a constant thing?
The dreaded 3800 RPM hesitation is cause 90% of the time by poor ground connections between the engine, the battery, and the car. Clean or replace all the under hood ground connections. On 86 model year cars , replacing/regrounding the pressure sensor's ground wire has helped (do not re-ground a 87 or later model year). If there is still a problem after that, look at cleaning the fuel injectors and (on a N/A) that your 5th/6th ports are operating correctly.
I took that off the RX7club forum
Thanks, hopfully this is that last of the problems
TR's resident A&P mechanic
I make a passive income from the comfort of my home, visit my blog, I would love to show you how to do the same
ISE Automotive-Mobile Mechanic and 24-7 Roadside assistance services from oil changes to full track car builds we do it all and get it done right the first time
So i changed the plugs and wires today and the oil pressure sensor because it was leaking like crazy and now it won't stay running and to top things off the rear main seal is toast. Does anybody wanna buy an Rx-7 probably need a new motor or does anybody have a good running motor for sale n/a or turbo in the i'm poor as fuck price range
<edit>
This might give you some hopes of a rebuild.
http://www.rx7club.com/showthread.php?t=395019
The prices in that thread are for a non-turbo engine. If you can do the work yourself, if shouldn't cost more than $700-$800 for a complete rebuild.
Sorry to hear about your car. But if you get a rebuild you will have a brand new engine sorta... So it should last you 100k or so.
TPS can be out,Timing can be out.
Bad fuel pump?
How do you know the rear seal is bad?
(Rear seal on engine?) and they are very easy to change.
Rotary Buddha has a S4 13B n/a engine forsale.. but he wants to much money for a stripped down (missing parts) engine..
Keep in mind n/a trannies are anywhere from $50.-$100. so see what hes tring to get for that engine.
I replaced everything in the order it came out, so maybe it was off to begin with. If somebody was a diagram or something that would be helpfull. The oil is just pouring out of the hole in the bottom of the bellhousing of the tranny so Im guessing its the rear main seal that is toast.
I have one
