d16a6 wagovan wont start.
Old Aug 2, 2012 | 10:08 AM
efkidd525's Avatar
I do what I do
Default d16a6 wagovan wont start.
so my wagovan wont start. just replaced the started and still nothing. I dont here any clicking when i tryin to turn the key. i can push start the car and pop the clutch and it worlks fine but i dont want to have to keeo doing that everytime
my oil light and my battery light are on. seen in pic beloew.
anyone know the problem
okay so i jumped the starter it works. where are the relays?
so i looked at the relay behind the left headlight. it looked really caroaded and nasty. hopefully thats my problem.
[URL=http://imageshack.us/photo/my-images/43/photofxi.jpg/][/URL
TR "Old Skool EF" Member #179
Old Aug 2, 2012 | 02:09 PM
DRMORTY's Avatar
Once Ruled The World .l..
Ignition key switch might be bad... it's in the column on the back of the ignition key assembly.
If you changed the starter and still nothing, I would try that next.
Do you know how to jump the starter?
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Aug 2, 2012 | 04:58 PM
efkidd525's Avatar
I do what I do
yes i do i jumped the starter and it worked.
Old Aug 3, 2012 | 05:58 AM
jdmpineapple's Avatar
nuetral safety switch on clutch jump it if not give me a call 813 410 0923
Old Aug 3, 2012 | 07:24 AM
BoostedRacerDad's Avatar
Pops
I agree with starting at neutral safety switch.
ectim
Just follow your clutch pedal up and you should be able to find it. Many times the rubber stopper that presses against the switch breaks off and ends up in your floorboard. If that's the case for you, use your finger to press the end of the switch in and try starting the car. MAKE SURE YOU'RE IN NEUTRAL!
The car will crank in gear with the switch bypassed.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Aug 3, 2012 | 04:20 PM
DRMORTY's Avatar
Ya, good thought.
TR
Old Aug 3, 2012 | 08:34 PM
Pops
Hey Morty, Your old CRX finally got a new ignition switch. I sent the bill to your house....
JoKie TuNinG
StricKlyMT
727-510-6301
Old Aug 11, 2012 | 08:34 PM
DRMORTY's Avatar
Good to know your keeping her running...
Hope you didn't pay to much... I have a stack of them...
TR
integrex
Sep 4, 2007 06:05 AM
methree
Oct 6, 2005 11:40 AM
kid4life4eva
Sep 19, 2005 07:47 PM
MOORESPEED12
Aug 7, 2003 11:50 AM
