HELP crx auto to manual swap and now no spark..
thanks guys reaLLY need to find a good working pm5 before i can get him to come out because im pretty sure my ecu is toast
CR-X count: 15
A.K.A CRXCRXCRX
Slowly built
Wtb: z6 turbo pistons, block guard, eagle rods, vtec sol and nice dual bend shifter.. Please text with info 727-614-5982
-jesse
CR-X count: 15
A.K.A CRXCRXCRX
Slowly built
-jesse
^ yea grounded a main power for the starter relay but idk honestly the ecu doesnt light up when i turn the key one and the CEL stays lite up
CR-X count: 15
A.K.A CRXCRXCRX
Slowly built
-jesse
CR-X count: 15
A.K.A CRXCRXCRX
Slowly built
-jesse
maybe ur under dash wire harness is from a automatic...cuz u change to manual n u forget to plug it again maybe u took off plug wit auto from under arm rest c if u forgot and plug it back or put the wires back just make sure it matches and plug iut back to c if it turns on or if wont work then call neal rywires connect wires spark n injection on ecu it will work perfect...
[ RICARDO_DYNO BOOST]
got her doen did thanks tho^ was because someone bypassed the main relay and when i put a real relay in it wasnt getttin gpower to the fuel pump or injectors...got it now tho starts up great and runs now
CR-X count: 15
A.K.A CRXCRXCRX
Slowly built
-jesse
CR-X count: 15
A.K.A CRXCRXCRX
Slowly built
-jesse
