auto to manual swap S13
Old Aug 28, 2004 | 06:57 PM
josht34237's Avatar
Revolutionary
Default auto to manual swap S13
has anyone have first hand experince doing this, how hard is it, what do I need to do it?
Old Aug 28, 2004 | 07:33 PM
SILVIA-S14's Avatar
Suck A Turd!
I found this......Its for S14 but it may be helpful
http://www.240sx.org/links/installs/s14_5speed_swap.htm
RiNKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Aug 28, 2004 | 08:20 PM
Epstein's Avatar
Retired
I've done it. Minimal wiring. You just need a ton of parts. You have to get dirty and lift heavy stuff, too.
I'd go to a u-pull-it style salvage yard to make sure you get everything. Basically everything between the differential and the block has to be changed.
There are plenty of corners that can be cut as well (used parts instead of new). I'd suggest getting a new Exedy clutch ($99 on eBay), and clutch master/slave/hose ($35/$25/$10). That leaves tranny w/bolts, driveshaft, shifter (w/boots and knob), flywheel w/bolts (resurfaced, of course), clutch hard line, clutch pedal, and most importantly starter bolts. That later are easily forgotten, and hard to find.
For wiring, just jumper the starter interlock. You might also want to connect the reverse switch and the speed sensor output. Download a FSM from zeroyon.com to figure that one out.
If you actually go through with this, I'd be happy to lend further technical assistance. It will only cost you a test drive in your GTI. I'm thinking about buying one.
Old Aug 29, 2004 | 07:09 AM
buck19's Avatar
Forever Broke Nissan
you alsoe need a manual tranny cross member cause the auto is exact oposites.
if you have the right tools and are doing it in the driveway it should take about a half a day of work. dont forget to drain the tranny first and get new tranny gear oil.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
