Pressure in the crank case
Old Feb 13, 2011 | 05:52 PM
  #21 (permalink)
patrick sakitis's Avatar
Originally Posted by chi town brat
My bet is that if you put the catch can on there you would either see steam or oil filling up and coming out of the catch can. Have you noticed either coming out of the valve cover relief that i think you mentioned in your first post?
Do you have an Oil Pressure gauge in the car? What does it read?
no oil out the valve cover or steam. Have oil on intake side turbo where filter is. oil is like 60psi when start up then goes down at idle around 20/25psi when wormed up. and boost gage looks 3d when boosting.
Old Feb 13, 2011 | 05:53 PM
  #22 (permalink)
Originally Posted by sullivanracing06
to much heat in the piston will make the oil ring stick to the piston and not float freely which will allow for the smoke and there to still be compression across the engine.
also, like someone else stated..... check to see if your pcv system is working well
car doesent smoke
Old Feb 22, 2011 | 03:18 PM
  #23 (permalink)
any one
Old Feb 23, 2011 | 08:17 AM
  #24 (permalink)
JoKiE crx4294's Avatar
popeye built!
If you have oil on the intake side, either the turbo is done or the return line is not flowing correctly.
Can't spell strength without tren
AAS...It's whats for dinner
Old Feb 24, 2011 | 04:44 PM
  #25 (permalink)
i also just hooked up an hose the valve cover tube and blew in it with my mouth and the turbo intake side started making a air noise where the air cleaner is which means its the turbo seal? right ! Or am I wrong? As of now i think that is the oil seal from the turbo that is passing boost through the seal and creating pressure in the crank case. please help me if i am wrong but i think that is what my problem is thanks and reply if u think i am right or wrong
Patrick
Old Feb 25, 2011 | 03:20 AM
  #26 (permalink)
popeye built!
You need a breather setup plain and simple dude..... weld 2 -10 bungs on the vc and run the two lines to a catch can.
CRXaddict
Jul 31, 2008 07:15 AM
TampaEntourage
Apr 25, 2008 01:02 PM
djlobes
Bike For Sale
Jan 20, 2008 11:04 AM
Shawnk
Aug 11, 2005 10:50 AM
buck19
Sep 13, 2003 11:38 AM
