Crank Case Ventilation Qs
Old Sep 4, 2003 | 09:01 PM
buck19's Avatar
Forever Broke Nissan
Default Crank Case Ventilation Qs
what is the purpose of modifiying the CCV
i know it has something do do with increased pressure and such, but can someone go into some thick details about it.
i remember the 4g prelude at SS having two oversized CCV bungs coming out of the valve cover and the hoses going to an aluminium box. i also noticed enthalpy's car having some things done to it.
If you have three quarters, four dimes, and four pennies, you have $1.19. You also have the largest amount of money in coins without being able to make change for a dollar.
Old Sep 4, 2003 | 10:50 PM
buck19's Avatar
so how would you rig something like that up. do they make CCV specific pumps. i want to learn all about this.
Old Sep 5, 2003 | 02:51 PM
0HP930's Avatar
Guest
Atmosperic pressure and some ventilation is all a crankcase really needs.
One thing I like about my dry sump system is that it is always ventilating the crankcase without contaminating the intake charge or needing aditional hardware.
Old Sep 5, 2003 | 08:55 PM
BLUE2KSS's Avatar
Mechanical Engineer
yeah, mine recycles the shit air. i just recently replaced my pcv valve and screen, that was some nasty shit built up after a while
Old Sep 6, 2003 | 10:33 AM
0HP930's Avatar
Guest
On older engines that have a lot of blowby its scary what a PCV system can cram into the the intake.
Old Sep 6, 2003 | 05:36 PM
BLUE2KSS's Avatar
Mechanical Engineer
i know. its some gross shit
Old Sep 6, 2003 | 08:28 PM
flybyuin2.2's Avatar
less crankcase pressure=free horsepower besides the fact that you can run low tension rings and have better ring seal like "Mars_302" said
Old Sep 9, 2003 | 07:48 PM
buck19's Avatar
so that would explain the sludge i have on my TB.
400HP your talking about a dry sump oil pan will basically take care of crank case ventilation and pressure in its self.
i want to know what actually goes on. like go deeper into the subject
so the little filter you see on the PCV does harm and no create cause you loose the pressure?
do you need positive, negative, or nuetral atmospheric pressure in the crank case?
