HELP!! Synthetic Oil Problem
Old Aug 4, 2001 | 08:42 PM
RicerX's Avatar
Icy Hot Stuntin
Were you using non synthetic before?
Im not really 100% sure whats goin on with your ride but Ive been told that switching from non synthetic to synthetic (or vice versa) can be unhealthy for your car if you do it too much. Did you let the previous (im assuming non sythetic) oil drain out completly? Did you also change the oil filter? If not there may have been some non synthetic left over in the filter that mixed with the new oil.
Thats weird that you say that the oil seemed thin because usually synthetic oils are alittle thicker than non synthetics.
I personally suggest you try to stick with the mobil.
I dunno though...Im no professional mechanic or anything...just my two cents.
mike.
"Ricey Hot Stuntaz" member #001
www.seductivecycles.com
Old Aug 5, 2001 | 08:17 AM
C VeX's Avatar
You probably spilled some outside the engine so its burning it off.Synthetic is a betterhigher quality petroleum oil that gives u better protection over conventional oil.Your car will run cooler thus u dont have to worry if u pass your 3000 miles recommended oil change.It Shouldn`t HARM you car in anywaybut synthetic was not recommended during the break-in stage when u first bought your car to let the bearings and rings seated right.Since your car has 17K miles i dont see that was a problem. BTWwhat grade oil did you use? 15-50 could give u a little sluggishness to your ride. Try use a lower grade next time.
Old Aug 5, 2001 | 02:48 PM
b16a2pwr's Avatar
ALLJDM
the only problem i have with this synthetic oil is that once you go to it you cant really go back. Well i know that you can but it leaves this sludge in the engine.. Just a thought. I use the part-synthetic
AIM: jasonbadler
813.508.PLAN (7526)
TR Notary Crew: #001
just wanna go fast
Feb 9, 2001 06:40 AM
marksaccord95
Jan 18, 2001 04:40 PM
Bill
Oct 29, 2000 11:21 AM
Bill
Jun 24, 2000 03:35 PM
