Help...shooting for 200whp
oh one more thing what will the impared flame travel cause? if you do not mind pm me a 200 whp motor setup like pistons, cams, stuff like that. in magazines seen an oem build attain this goal thanks...
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
the flatter the piston the better. IF i was to go with any kind of high compression piston it would be a endyne rollerwave , coated.
RIP Robert Kolp aka 00ek 4/07
_Jake D
_Jake D
JDM ITR motor with middle layer taken out , tuned , Nasty header , Good intake , Light flywheel , Cam gears
I would expect this motor to see 190WHP + .. I think 200 is possible with race gas and a bump in timming ...
Hondata saves lives
Hondata saves lives
I have a question, yall are saying that he cant have 180 hp 184 torque on a honda engine? I ran my car on dyno a bunch and come out with
234.7 hp 246 tq at 5000 rpm
240.6 hp 210.6 tq at 6000 rpm
Is this wrong? Is the dyno incorrect? My car is a 95 teg ls turb @22 lbs. Just tryong to figure out why people were saying the numbers are incorrect? Thanks.
--Its all good--
--Its all good--
LS Turbo's are different ...
They routinely make more TQ than HP .. Just as some D-Series do as well ...
An all motor Honda revs much higher and has higher lift / Longer duration cams that bring the powerband up and the torque curve down ...
Hondata saves lives
Hondata saves lives
im just going to say this.
IF you want 200+ whp For cheap liek most of you Cheap fucks on here do ..... put a 100 shot on it. end of story.
_Jake D
_Jake D
ps , i plan on making 330ish HP with a STOCK b20 on a shot.
_Jake D
_Jake D
