Help...shooting for 200whp
I do have to say that SS's dyno did read a tad high. On my 1st setup which was simular to this person I put down 179WHP at 169 FTLBS of TQ all motor, and on the spray B4 it Poped I put down 285WHP at 277FTLBS of TQ. And John(not in this game anymore was my go to person when I needed anwsers. He could deff tune the shizzel out of a motor..
If you are woundering why the motor poped,i ts because I had a faulty bottle pressure guage. We thought the bottle was at 1200 when it was at like 1400PSI right at the bursting limit, and the motor ran lean for a sec and BOOOOM, got a nasty nitrous backfire that split the intake in half, shot the filter acrossed the shop, and snaping a fuelrail bolt from the intake mani tweaking the fuel rail.. shitty day it was ......
Modified Racing
Street Tuning & Dyno Tuning the greater east coast area for over 10 years and running!
AEM/HONDATA/MOTEC/FAST/DEFI & More
EFI-101 Certified
(941)628-4988
EFI-101 Certified
(941)628-4988
Guest
Posts: n/a
dude no one is trying to start a fight... i am just simply telling you that your car does NOT put down those numbers... i would take it somewhere and dyno it again, as to get a good base line/starting point so that you see how much further you need to go...
Originally Posted by TIM TIM TIM
your vtec lagged?
i'd never heard of vtec lag before.........thanks for the info!
I BUY RROD XBOX 360'S FOR TOP DOLLAR!!!!..PM ME!!!
200WHP All motor ?
GSR Block
81.5mm CTR Pistons
GSR Rods (Or EAGLE if youw anna spray it)
ARP Rod bolts
ARP Headstuds
ITR/CTR Head (Ported B16 will work)
JDM ITR/CTR cams
ITR OR JG Intake manifold
ITR TB
REAL Header
P30 HG - No Middle leayer
Chipped P28 tuned
New OEM Igntion (wires , cap , rotor)
Walbro 255
Wet 150 Shot for fun
GSR Block
81.5mm CTR Pistons
ARP Rod bolts
ARP Headstuds
JDM ITR/CTR cams
ITR TB
REAL Header
Chipped P28 tuned
Walbro 255
Hondata saves lives
Hondata saves lives
Originally Posted by BoostedSRT
200WHP All motor ?
GSR Block
81.5mm CTR Pistons
ARP Rod bolts
ARP Headstuds
JDM ITR/CTR cams
ITR TB
REAL Header
Chipped P28 tuned
Walbro 255
GSR Block
81.5mm CTR Pistons
ARP Rod bolts
ARP Headstuds
JDM ITR/CTR cams
ITR TB
REAL Header
Chipped P28 tuned
Walbro 255
steve
K series on crack
Street Car on 25PSI V V V V V V
http://www.youtube.com/watch?v=_sn1WsbI0UQ
S D M
K series on crack
S D M
I've seen this EXACT setup crest 200WHP on a dynojet multiple times ...
Neils setup in his hatch I belive is similar and made 203WHP ??
Now with More compression / Larger cams such as Toda Spec B/C or Jun II/III Or something such as Crower Stage 4/5 you could make much more power but you powerband becomes more so "peaky" than a 200WHP all motor setup already would be ...
If I wanted a track only car it would have a fully done Portflow/RLZ head 12.8:1 Flycut pistons , 84mm sleeved with the combustion chambers on head opened up and some HUGE cams ... This could make 230/240WHP but would only run on race gas reliably etc ...
A 220WHP Motor hit with a 150 wet progressive Would make nasty power and porbally hook on some 235/60/15 Mickeys ...
Hondata saves lives
Hondata saves lives
Originally Posted by na200whp
CTR pistons are not the best option. this setup will need a larger cam to hit 200. As for te 184TQ most likely there is a spike on the chart giving the high read.
steve
steve
i heard of this before but want to get your take on it. as why not to use the ctr's.
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
TR "OLD SKOOL EF MEMBER" #05
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
steve
K series on crack
S D M
K series on crack
S D M
steve
K series on crack
S D M
K series on crack
S D M
to much compression and impared flame travel due to large domes . if this is for a street car go w/ JDM ITR's. you still get the piston coating but w/ a more streetable compression. my $.02
steve
steve
yeah heard of too much compression (in a ls\vtec) for a street car or reliable one. did not hear of the imared flame travel. only like the jdm type r has the coating like the ctr's? cause the p30's do not. with ctr's in a ls\vtec i think (correct me if i am wrong) the c.r. will be about 12.5 .
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
THE FEW
THE STRONG
THE BRAVE
NATURALLY ASPIRATED
