Well, look what we have here......
Originally posted by ~Jason~
w00t josh, im goin ls/vtec on the crx too
.. already got spoon ITR ceramic coated pistons, eagle h-beam rods, arp rod bolts, head bolts, and head studs, all of this is in a b18a1, im also throwin on a b18b head on to raise compression a little more than 11.5:1, nothin beats the sound of vtec screamin
Chavez Motorsports
The reason CMS fabrication is closed!! Click me!
11.965 @ 114 Supercharged Teg...RIP
Chavez Motorsports
.. already got spoon ITR ceramic coated pistons, eagle h-beam rods, arp rod bolts, head bolts, and head studs, all of this is in a b18a1, im also throwin on a b18c head on to raise compression a little more than 11.5:1, nothin beats the sound of vtec screamin
LS/VTEC is the new bandwagon.
They already come with rod bolts plenty stong enuff for any n/a application. To my knowledge eagle uses arp for their rod bolts.
Do you relize that eagle rods use a seat clip style wrist pin?
Hence you will have to have a groove carved into each of your pistons to be able to use the seat clip wrist pin style which you will have to purchase from srp/je...
Originally posted by mtber
So let me get this. You are using ITR pistons on eagle h-beam rods ?
eagle rods up for sale in t-minus 3,2,1......
there are all motor hondas in the 9s. and sure, you wont make ridiculous power all motor, with only maybe 2.2 liters max, and 4 cylinders, but its still impressive to see guys generating 300 hp out of em. and 9 seconds in an all motor fwd car is unbelievable IMO. to think the fastest unibody hondas are only going 8.3's to 8.4's right now and all motors are doing 9's? thats awesome
Chavez Motorsports
Chavez Motorsports
Guest
Posts: n/a
