ls/vtec cam question
Old Apr 12, 2004 | 10:31 AM
99B16Si's Avatar
there ya go
Old Apr 12, 2004 | 10:32 AM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
i say ctr intake in itr ex cam. not worth upgrading depending on your compression and internals.
tamparacing.com
Old Apr 12, 2004 | 11:59 AM
Gotin's Avatar
Sayien
i think you should stick with the honda cams, you can upgrade to stage1 skunk 2 cam, skunk clams that its a little bit more aggressive then the ctr. dont do todas unless you clay test the motor.
-B.J.F-
Old Apr 12, 2004 | 12:01 PM
DONT SLEEP's Avatar
S1's MUSCLE RELAXER
ask neal about skunk 2 cams stay honda oem means more
tamparacing.com
Old Apr 12, 2004 | 12:28 PM
  #17 (permalink)
mtber's Avatar
Default Re: ls/vtec cam question
Manufacturer / Intake / Exhaust
EF-1 m24 cams 12.1 mm, duration - 258 @1mm 12.1 mm, duration - 258 @1mm
Toda Spec A 11.6 mm, duration - 250 @ 1mm 11.2mm, duration - 240 @ 1mm
Toda Spec B 12 mm,duration - 255 @ 1mm 12 mm, duration - 245 @ 1mm
Toda Spec C 12.5 mm,duration - 255 @ 1mm 12.5 mm, duration - 255 @ 1mm
Jun Type 1 10.9 mm, duration - 265.3 @ 1mm 10.0 mm, duration - 268 @ 1mm
Jun Type 2 12.0 mm, duration - 266.6 @ 1mm 10.9 mm, duration - 265.3 @ 1mm
Jun Type 3 12.0 mm, duration - 265.3 @ 1mm 11.5 mm, duration - 265.3 @ 1mm
Spoon Sports 11.53 mm, duration - 256 @ 1mm 11.13 mm, duration - 245 @ 1mm
Skunk 2 stage1 11.58 mm, duration 252 @ 1mm 10.9 mm, duration 249 @ 1mm
Skunk2 stage 2 12.3 mm, duration 266 @ 1mm 11.8 mm, duration 262 @ 1mm
Skunk2 stage 3 12.8 mm, duration 273 @ 1mm 11.5 mm, duration 273 @ 1mm
Crower 63400 10.69 mm, duration - 244 @ 1mm 9.83 mm, duration - 231 @ 1mm
Crower 63401 11.38 mm, duration - 249 @ 1mm 10.54 mm, duration - 240 @ 1mm
Crower 63401T 11.81 mm, duration - 240 @ 1mm 11.30 mm, duration - 237 @ 1mm
Crower 63402 11.84 mm, duration - 258 @ 1mm 11.84 mm, duration - 251 @ 1mm
Crower 63402A 11.84 mm, duration - 246 @ 1mm 11.81 mm, duration - 239 @ 1mm
Crower 63403 12.04 mm, duration - 267 @ 1mm 11.84 mm, duration - 257 @ 1mm
Integra Type R 11.5 mm, duration - 240 @ 1mm 10.5 mm, duration - 235 @ 1mm
Civic Type R 11.5mm, duration - 243 @ 1mm 10.5 mm, duration - 235 @ 1mm
On a factory itr valve train (valve springs & retainers) I wouldnt go with anything more agressive then a toda spec a or skunk2 stage 1 cam profile.
Old Apr 12, 2004 | 01:52 PM
  #19 (permalink)
Vito_Corleone's Avatar
TR Balla Donor Supreme
If you're compression is going to be mid 11s upgrade your valvetrain and get some Skunk2 Stg 2s, then rev that bitch to 9 or higher.
