View Poll Results: What do you do?
Pop it in neutral and brake to a stop
51.92%
Rev-match then brake to a stop
40.38%
Downshift without rev-matching
7.69%
Voters: 52. You may not vote on this poll
Blip that throttle!!!
Old Jul 12, 2005 | 12:19 PM
  #21 (permalink)
F*r*a*n*k*e*i's Avatar
Originally Posted by Orion ZyGarian
It sounds fucking cool when a '67 Camaro is at ANY RPM level
Especially with hooker long tubes, 2.5" dual stainless pipes, and dynomax super turbo mufflers.
Old Jul 12, 2005 | 01:04 PM
  #22 (permalink)
24-7's Avatar
Civic Racing eXperiment
Originally Posted by Fordified
Why would you even downshift when coming to a stop? I kick it into neutral (usually I'll blip the throttle and pop the shifter out without touching the clutch) and apply brakes. Rev matching and downshifting is annoying because you aren't racing, just driving. Brakes are MUCH easier to replace than a clutch.
I agree
Old Jul 12, 2005 | 01:26 PM
  #23 (permalink)
BeQuietAndDrive's Avatar
the whistles go whooo!!!1
Downshifting when coming to a complete stop is just goofy. If I'm in 5th gear, I'm not going to row down through every one just so I can stop.
Now, if I'm in 4th, and need to slow down for a corner, I will rev-match/heel-toe, etc.
Old Jul 12, 2005 | 01:30 PM
  #24 (permalink)
Country Boy's Avatar
can survive...
slip into neutral and brake.... Once in a blue moon Ill downshift just to do it.
Old Jul 12, 2005 | 01:54 PM
  #25 (permalink)
Epstein's Avatar
Retired
Downshift (rev-match) one gear, then clutch in around 1500. The tC has a crappy electric gas pedal that lags and has no feel, so there's a minimum of rev matching and funny business at a light. The 240sx gets all manner of crazy shifting techniques in the turns, but still only drop one gear at lights.
Old Jul 12, 2005 | 01:57 PM
  #26 (permalink)
osama tim laden's Avatar
kings cannot fall.
Originally Posted by Frank
Throttle response is overrated.
hopefully youre joking.
Old Jul 12, 2005 | 01:58 PM
  #27 (permalink)
kings cannot fall.
oh, and to answer the question, i just shut the key off in gear, and slam to a stop.
works pretty good.
Old Jul 12, 2005 | 06:57 PM
  #28 (permalink)
Illswyn's Avatar
My Tempo did that, when it decided to stall regularly IN GEAR. In an automatic. I was driving along, and it shut off, I popped it in neutral, coasted off the road, back into park, turn the key, get back on the road.
Girlfriend's friend was like, wow...quick thinking. I was like, wow, the car f*****g stalled. Shitty damn automatic. At least with a manual, I can rev it so it stays running. Or at the very least, start it back up while driving (you know, put it in 3rd or 4th, pop the clutch)
Driving a manual, I tend to stay back, and coast up to lights. I like to be able to drop it into second or third, and get moving again. If it's obviously going to be backed up even when I get there, I just put it in neutral and begin braking.
And I don't hit my damn brake unless I intend to slow down, or stop. None of the damn tap-tap-tapping my brake just because I'm unsure. I either use it, or stay off the damn pedal!
Old Jul 12, 2005 | 08:55 PM
  #29 (permalink)
TIM TIM TIM's Avatar
could be worse
I downshift at times just because I love the sound but I try not to because I dont feel like replacing a clutch any time soon. Is it bad to pull in/out of gear without the clutch (if the rmps are right, I can go in and out of every gear with no grind or anything)
aim:because tim said
Old Jul 12, 2005 | 10:51 PM
  #30 (permalink)
NegativeGeForce's Avatar
+1 on engine braking being stupid and only used to show off. The streets arent a race circuit...engine braking does not do anything other then put unneeded wear on parts. Id rather change the brakes/rotors then a motor/clutch.
Those of u that think its cool to engine brake never change a motor or clutch. When u do...u will think twice about engine braking.
