View Poll Results: What do you do?
Pop it in neutral and brake to a stop
51.92%
Rev-match then brake to a stop
40.38%
Downshift without rev-matching
7.69%
Voters: 52. You may not vote on this poll
Blip that throttle!!!
Old Jul 14, 2005 | 03:19 PM
  #41 (permalink)
Jordan Y.'s Avatar
15 seconds EXHILARATION
Originally Posted by Fordified
nah, the only time its bad for the synchro's is if they are making noise. Sometimes if you don't get the RPM's right it will either grind or you'll hear a whirring sound as the synchro's match speed. That will wear them out, but if the RPM is right and it slides right in, its fine.
I'm still not sure about my method. I didn't want to have to look at the rpm and I've never been able to pinpoint it by sound, so I didn't like driving around blipping to rev match though it was the smoothest way. I found that if I was fast enough, I could push or pull the shifter against the next gear with moderate force as the rpm dropped and as it reached the rpm where it matched, it would pop into gear. No griding unless I didn't put enough pressure on it, but it wasn't as smooth as revving back up to rev match and slide it in on acceleration and not deceleration. What do you think about that method? It's faster, but does it put more wear on the car?
Old Jul 14, 2005 | 07:56 PM
  #42 (permalink)
Illswyn's Avatar
The only time I downshift is when I know the light will be changing, and want to get a jump on it. Downshift into 2nd or 3rd, leave the clutch down, then let off and hit the gas when the light changes. Otherwise, Just leave it in neutral.
Even those that have to keep the revs up to keep it from stalling, just hold lightly on the gas to keep it revved in neutral, while stopping. When my Prelude had a bad carb that's what I had to do.
Or you COULD consider fixing the problem.
Old Jul 14, 2005 | 08:38 PM
  #43 (permalink)
Rdline1's Avatar
Hi Hi Hi?
i always just popped it into neutral and braked.
98 Camry w00t! (daily ride)
91' Eclipse GS-t (she's alive!!)
AOL IM: usfbull49
Originally Posted by Frankie
When a jelly fish comes out of my ass, I'll take pics.
Old Jul 14, 2005 | 11:38 PM
  #44 (permalink)
perdition79's Avatar
Grift Consultant
three years of rev-matching downshifts at every damn stop light killed the 3rd and 4th gear synchros on my old neon. so my next stickshift car will definitely go into neutral when stopping. brakes are cheaper than a clutch and a tranny.
"The genius of any slave system is found in the dynamics which isolate slaves from each other, obscure the reality of a common condition, and make united rebellion against the oppressor inconceivable." ~Andrea Dworkin
"If... the machine of government... is of such a nature that it requires you to be the agent of injustice to another, then, I say, break the law." ~Henry David Thoreau, 1849
That's right, bitches, TWO quotes!
