Engine Management!
Old Dec 28, 2004 | 06:11 PM
  #21 (permalink)
0HP930's Avatar
Guest
Megasquirt II has support for knock control using a delphi/gm knock sensor.
The only thing the systems like AEM really have on MS II is slightly larger tuning tables and sequential injection.
Old Dec 29, 2004 | 01:23 AM
  #24 (permalink)
Slash's Avatar
THE HAMMER
Q. Can I do sequential injection with MegaSquirt?
A. There are two common sorts of injection:
Throttle body injection - usually one or two injecotrs for the whole engine
Port injection (aka. Multi-Port) - one injector per cylinder
Then there are three common modes of injection timing:
batch - all injectors fire at once, but not timed to any specific cylinder event,
bank - ½ the injectors fire at once, then the other ½, and so on, but not timed to any specific cylinder event,
sequential - each injector fires at a specific point in the 4-stroke cyle for each cylinder (i.e., 8 independent timing events)
Throttle body injected cars are usually batch or bank fire, simply because of the geometry. Most port injection set-ups before the mid-1990s were bank fire as well (including GM Tuned Port Injection for the 305/350).
Sequential injection requires:
at least as many injectors as you have cylinders, with one dedicated to each cylinder (i.e., not a 4 injector TBI on a 4 cylinder).
as many injector drivers as you have cylinders,
and also requires a camshaft position sensor (a crank sensor is not adequate for a 4-stroke cycle engine).
However, sequential injection does not necessarily mean you are injecting into an open intake valve all the time. The intake valve is only open less than 30% of the time in a typical 4 stroke engine. Once you are trying to produce more than about 25% of maximum HP your injectors are firing for longer than the intake valves are open. If your maximum HP is correctly calibrated to a safe 80% duty cycle, your injectors are injecting well over 50% of the time on closed valves.
MegaSquirt has just two injector drivers (that can handle up to ten injectors each), and no provisions for a cam sensor signal, so it would be difficult to make it into a sequential injection system.
The benefits of sequential injection are that:
you may get slightly better mileage and lower emissions at low engine speeds,
you can tune each cylinder's fuel amount independently (if you know how).
The effect on maximum horsepower is generally negligible.
I dont feel like a sig today.
Old Dec 29, 2004 | 01:32 AM
  #25 (permalink)
Slash's Avatar
THE HAMMER
Originally posted by John
so is MS batch fire?
I know its bad. And i understand it dosent allow for trimming each cyl. My sds was batch fire as well I think. What is really what brings it back? esp when teh price is so cheap?
Old Dec 29, 2004 | 06:20 AM
  #28 (permalink)
Slash's Avatar
THE HAMMER
Gotchas. But for the SR u could just run 5% richer and not make peak power (3cyls 5% too rich) but be reliable then right?
Old Dec 29, 2004 | 08:24 AM
  #30 (permalink)
BOOST JUNKIE's Avatar
slow
If you only care about WOT and are OK with doing crude things like hold your foot on the gas for 20seconds before the car will idle, and run 5% richer accross the board to make up for an airflow imbalance, I'd say just forget the standalone, ditch the EFI all together and install a carb... beacuse it sounds like the kind of stuff I do when I tune my brother's dirt bike.
