Random shaking in first gear ONLY
Old Jan 9, 2010 | 07:41 PM
  #21 (permalink)
Sirusx's Avatar
Sirus
Originally Posted by Stoopid Wendy
You can't flip it, in any way. The flywheel gets un-even, hot spots and cracks. It has to be resurfaced to make new again. The new clutch disc will take shape to the old flywheel and cause the pressure plate is smooth all the un-even wear makes it chatter.
Just like doing a brake job, you can pad slap it but it's not right. Your asking for noise, and with a clutch your asking for chatter.
Alot of small shops don't resurface because they have to take the flywheel to a tranny shop to have it turned, it takes time and you might never have a problem.
john
So do you really think that could be the issue then since he Didn't resurface it?
Old Jan 10, 2010 | 04:40 AM
  #22 (permalink)
Stoopid Wendy's Avatar
see dick run
If the shake only happins as you let the clutch out in first or second (like above)then yes.
How long ago did they do the clutch?
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
Old Jan 10, 2010 | 06:19 AM
  #23 (permalink)
GNs-r-slow's Avatar
Bondsman
Did the mechanic that you try to diagnose it the same one that done the clutch?
Old Jan 10, 2010 | 06:27 AM
  #24 (permalink)
95coBraSVT's Avatar
banana republic
Originally Posted by Sirusx
Really hope its not the clutch just got it replaced at 96k miles =(
In case my mechanic gives up, anyone know a reputable mechanic that won't charge me a arm and a leg to look at it and possibly get it fixed?
Dave at Genium Preformance. His screen name on here is 91notch
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Jan 15, 2010 | 07:58 AM
  #25 (permalink)
fuelie327's Avatar
it's definitly clutch chatter. reman flywheels are only 50 bux
