Random shaking in first gear ONLY
Old Jan 8, 2010 | 07:01 PM
302GTS's Avatar
Resident TOB Killer
First guess = clutch chatter.
Old Jan 8, 2010 | 08:11 PM
Sirusx's Avatar
Sirus
Originally Posted by Stoopid Wendy
Sounds like you need to find another mechanic, Has he felt the shake?
john
Yes, he went for a ride with me in the car and it did the shake right off the bat. He thought it was a engine vacuum leak but when he did his search for the leak on the car (Thursday) he was unable to find any sort of vacuum leak so it turned into a.."I don't know what exactly it is but everything checks out fine as far as the engine goes according to my computer diagnostics"
Old Jan 8, 2010 | 08:12 PM
Sirusx's Avatar
Sirus
Wouldn't clutch chatter effect all the gears though? (i'm a car noob bare with me)
Old Jan 8, 2010 | 11:07 PM
302GTS's Avatar
Resident TOB Killer
Nah, mine chatters a bit in first, some in reverse, and in 2nd if I'm going very slowly into the gear.
Old Jan 9, 2010 | 06:09 AM
Stoopid Wendy's Avatar
see dick run
That's what they do. Because it's a 03, the computer is very smart and like you said, no check engine light.
Is the intake hose from the mass air to the throttle body tight and no cracks? Sometimes they can crack and open when you take off from a light and the engine gets fresh un metered air that will trick the computer and make it run funny.
I think its the clutch.
john
handle every stressful situation like a dog: if you can't eat it or play with it, just pee on it and walk away.
Old Jan 9, 2010 | 06:19 AM
Sirusx's Avatar
Sirus
john
Really hope its not the clutch just got it replaced at 96k miles =(
In case my mechanic gives up, anyone know a reputable mechanic that won't charge me a arm and a leg to look at it and possibly get it fixed?
Old Jan 9, 2010 | 06:48 AM
  #17 (permalink)
see dick run
Did they resurface the flywheel when they did the clutch? They tend the chatter if you don't.
john
Old Jan 9, 2010 | 10:25 AM
  #18 (permalink)
Sirusx's Avatar
Sirus
john
Negative i think he said he flipped the flywheel to the other side?
Old Jan 9, 2010 | 11:07 AM
  #19 (permalink)
see dick run
You can't flip it, in any way. The flywheel gets un-even, hot spots and cracks. It has to be resurfaced to make new again. The new clutch disc will take shape to the old flywheel and cause the pressure plate is smooth all the un-even wear makes it chatter.
Just like doing a brake job, you can pad slap it but it's not right. Your asking for noise, and with a clutch your asking for chatter.
Alot of small shops don't resurface because they have to take the flywheel to a tranny shop to have it turned, it takes time and you might never have a problem.
john
Old Jan 9, 2010 | 12:52 PM
  #20 (permalink)
Mars_302's Avatar
Race Photographer
you have an aftermarket shifter in it?
