another missfire problem!
Old Jan 3, 2010 | 09:12 PM
  #21 (permalink)
EFI-Unlimited's Avatar
Originally Posted by Tiffiny
Thought you might like that one....
Brian
EFI-Unlimited
Old Jan 3, 2010 | 09:17 PM
  #22 (permalink)
Tiffiny's Avatar
I can fix your bullshit
Brian
EFI-Unlimited
I did, it made me chuckle .atleast that nonsence came from you
Old Jan 4, 2010 | 12:34 AM
  #23 (permalink)
GNs-r-slow's Avatar
Bondsman
X2.....there's not a whole lot of tech posts on carb stuff here. cant understand why
I would love to FI my turbo project....your right, I dont have the knowlege or the funds so I stick with cheap(er) and what I can work on.
Old Jan 4, 2010 | 03:14 AM
  #24 (permalink)
harold harper's Avatar
h9
all new vaccum lines.breaks up amid atop rpms under load.if you leave it 2 gear and gradually build up rpms it won"t sputer.tried another coil already.the only things that i haven"t tried are a new set of injectors,ingniton moduel,and efi harness.tommy i will take a look at those salt/pepper things later.i was going to take them apart last night,but it was getting colder and darker.
Old Jan 4, 2010 | 06:49 AM
  #25 (permalink)
95coBraSVT's Avatar
banana republic
Also, take a lesson from 95cobrasvt. Make sure your plug wires are sequenced correctly. Not even a carburetor will fix that.
So true...So true LMAO
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Jan 4, 2010 | 06:50 AM
  #26 (permalink)
95coBraSVT's Avatar
banana republic
Right there. I thought you had replaced it already.
Old Jan 4, 2010 | 04:42 PM
  #27 (permalink)
h9
found part of my numerous problems.THE FUCKING ROCKERS WHERE GETTING STUCK TO THE 3/8 STUDS.THESE ARE NOT TRUE RR ROCKERS,THEY ARE THOSE STEEL ROLLER TIP ROCKERS WITH THE BALL SOCKECT.i will be picking up a new set of true rr tomorrow.these steel ones hang down to far and bottom out againts the stud.
Old Jan 5, 2010 | 03:30 PM
  #28 (permalink)
herrcomestrouble's Avatar
not running any MSD or other brand ignition box are you?
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Jan 5, 2010 | 04:55 PM
  #29 (permalink)
GNs-r-slow's Avatar
Bondsman
How's it Cody??? You been hiding out?
Old Jan 5, 2010 | 05:39 PM
  #30 (permalink)
h9
problem found.to short of pushrods.cause rockers to lock up againts rocker studs when hot andf high rpm
