SN-95 brake conversion
Old Aug 20, 2008 | 04:32 PM
  #21 (permalink)
S281-335's Avatar
Maximum Motorsports maks a decent manual brake conversion kit. I used a old SVO master cyl. It is a 1 1/8 " bore, supposed to be about the biggest. some Linchon cast iron units are the same. I used M/M perportioning valve delete kit and a manual valve for the rear bias, that replaced the spacer in the hardline on the pass side by the hood hinge.
There are an assload of options, Decide on what wheels and what you are using it for and that will decide your brake options.
Good luck and keep it safe!
Old Aug 20, 2008 | 04:58 PM
  #22 (permalink)
GNs-r-slow's Avatar
Bondsman
15 inch wheels, street / strip only, not a daily driver
Old Aug 20, 2008 | 05:22 PM
  #23 (permalink)
Tiffiny's Avatar
I can fix your bullshit
no sn 95 contol arms you wont be happy
85 town car has a big bore i tried to call areospace today to find which chrsyler master they wouldnt tell me inow its like 30 bucks with a reservoir
they sell it 4 160 bs
ill keep looking i know i have it written down somewhere
Old Aug 20, 2008 | 05:24 PM
  #24 (permalink)
Tiffiny's Avatar
Originally Posted by KAILUAZ
Tru, it gets tricky when you mix match. I'm swapping the entire 95 K member, arms, spindles, etc... to make it simple. If you do your homework you can make just about anything work though.
its the same
Old Aug 20, 2008 | 05:47 PM
  #25 (permalink)
GNs-r-slow's Avatar
Bondsman
Originally Posted by Tiffiny
its the same
Same as ???? Gives you a wider track as well right?
Old Aug 20, 2008 | 05:52 PM
  #26 (permalink)
GNs-r-slow's Avatar
Bondsman
Originally Posted by $hawn
that will make the front track WIDE! you won't have enough inner tierod to reach
fox control arms, s/n ball joints, spindles and brakes is the way to go
Thanks, a definate answer!!! What did you do on Josh's rear brakes? Was that a complete SN rear or did you do something different with a bracket for the caliper? Which axles were used? Sorry for all the ?'s but I def want to keep the stock width on front and rear, thanks
Old Aug 20, 2008 | 05:59 PM
  #27 (permalink)
Tiffiny's Avatar
yes its too wide and k member are the same the only k member thats diff is the inline six ,only control arms are different
96 and up are not the same k member
Old Aug 20, 2008 | 06:01 PM
  #28 (permalink)
$hawn's Avatar
lives in a glass house
on the rear josh has s/n calipers and rotors with fox length axles. custom backing plates FTW
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old Aug 20, 2008 | 06:21 PM
  #29 (permalink)
GNs-r-slow's Avatar
Bondsman
Ahhh, Thanks. I have a complete sn rear and K-member to get all parts from just lacking sum of those custom brackets
