SN-95 brake conversion
Old Aug 16, 2008 | 07:13 PM
GNs-r-slow's Avatar
Bondsman
Default SN-95 brake conversion
I just bought complete 95 k-member and rear. I looking to install in a 79 Fox with manual brakes. Is therere special parts needed to make this work with good brakes. I also got the booster, master cylinder and proportioning valve. I'd rather go manual if it can be done cheap!!
Old Aug 16, 2008 | 08:38 PM
MiDiablo's Avatar
I had BM$ do mine. He had to make a specific bracket to fasten the calipers... Other than that.... I've got no idea
Old Aug 16, 2008 | 08:41 PM
GNs-r-slow's Avatar
Bondsman
I have a complete rearend with calipers, brackets, hoses complete.
Did shawn set yours up manual or power? Thanks
Old Aug 16, 2008 | 09:35 PM
Tiffiny's Avatar
I can fix your bullshit
thats a good year to do .its a 2 port master .a master from a 85 lincoln town car works great too.put it together w power brakes and see how it feels.my car stops on a dime no locking up very positive feeling.but the last one i did i needed to put an adjustable proportioning valve on it .which is simple nice union on firewall pass side
ill call you this week about the top
Old Aug 16, 2008 | 09:41 PM
Tiffiny's Avatar
if you want to go manual ill look up the master.its off of some chrysler forget exactly.big bore works nice and cheap.put a few on some race cars
Old Aug 16, 2008 | 09:50 PM
GNs-r-slow's Avatar
Bondsman
Originally Posted by Tiffiny
if you want to go manual ill look up the master.its off of some chrysler forget exactly.big bore works nice and cheap.put few on some race cars
Thanks John, as far as the pedal rod will my original 79 manual brake rod work with this set up or will I need something different.
As far as the top, youll have to come take that bish off!!!! Tools here, I dont have time bro. I'll keep the car till you can make arrangments to come get it, if that helps. If not let me know soon cause I finished rapin it today for the last few little things I wanted.
Old Aug 16, 2008 | 10:01 PM
Tiffiny's Avatar
i believe so but you will need a block to mount it to.you can fab something up or buy one.ill call you on monday to figure something out.been real busy
Old Aug 16, 2008 | 10:50 PM
GNs-r-slow's Avatar
Bondsman
This car came factory w/ manual brakes and manual steering
Old Aug 16, 2008 | 11:04 PM
Tiffiny's Avatar
sweet never mind .but i would still up grade the master
Old Aug 17, 2008 | 12:11 AM
GNs-r-slow's Avatar
Bondsman
If you remember which large bore M/C it was it would be much appreciated
