Sudden NO OIL pressure
Old Oct 17, 2007 | 02:34 PM
  #31 (permalink)
91Notch's Avatar
Is workin on his car
Originally Posted by Matt the Pilot
I was told that these shafts tend to twist up on strong motors and the chances are the pump is fine. So I'm going to attempt to install a new shaft through the dist hole with a magnet and some other type of ingenuity I may come up with. If I get the shaft in the pump I'll test it to see how it works. I just don't want to accept the fact that the pump is gone (because I don't want ot have to swap the bitch.)
Ha ha ha good luck with that. If your pump isn't locked up you have more luck than I do.
Old Oct 17, 2007 | 04:19 PM
  #32 (permalink)
Steve B's Avatar
brings his heater.
i'm the king of doing that btw, i had one i put together and forgot the little holder on the shaft.
Old Oct 17, 2007 | 04:37 PM
  #33 (permalink)
LS1COUPE's Avatar
Destroyer of fords
if you are going to try it without replacing the pump (i wouldnt) then go with a motorsports aftermarket one and not another stocker. good luck.
Old Oct 17, 2007 | 05:40 PM
  #34 (permalink)
Matt the Pilot's Avatar
ZAP yo dumb ass!!!!
Originally Posted by $hawn
dont get your hopes up...lol
Well... I did... And they were smashed to pieces.
Got the new shaft in (it was like surgery trying to fish that bitch into the pump through the dist hole while sticking a long "needle" type object to hold it down while I pulled the magnetic stick off.)
Got the drill on it (and by no means is it a weak drill. It's a high torque plug-in, industrial drill) and it won't budge in either direction.
Time for a high volume OP.
I still haven't decided how I'm going to "attack" the job of the swapping the pump. I really don't feel like yanking out the motor.
Matt Patton
RIP Jason Harrill 6-12-06: Died doing what he loved
Old Oct 17, 2007 | 06:03 PM
  #35 (permalink)
Tiffiny's Avatar
I can fix your bullshit
i can be done in car no problem you dont have to lower the k frame good luck tell us what in side it
Old Oct 17, 2007 | 06:06 PM
  #36 (permalink)
JohnnyPC1's Avatar
That on the back, take the pan off thing sounds like a pain in the ass! Buy a quarter barrel, invite all your friends over and have that thing out and in, in an evening...
Old Oct 17, 2007 | 06:10 PM
  #37 (permalink)
ZAP yo dumb ass!!!!
I don't know about you but when I have more than one person helping me yank a motor shit gets lost. Tools/parts/hardware/etc. Even then I only trust a certain few people to work on my car with me.
I'm definately going to try to yank the motor up as far as possible without disconnecting it from the trans.
Matt Patton
Old Oct 17, 2007 | 06:17 PM
  #38 (permalink)
Na306StAnG's Avatar
Flowmaster nut swinger
To bad you don't know anyone with a lift.......
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Old Oct 17, 2007 | 06:19 PM
  #39 (permalink)
MiDiablo's Avatar
Old Oct 17, 2007 | 06:47 PM
  #40 (permalink)
Mars_302's Avatar
Race Photographer
pulling the motor is easy. You dont it enough times, 2 hours tops. Dont froget a good oil pangasket not the cheap one
