Sudden NO OIL pressure
You shut up. I don't want to hear that. Haha
Is it possible to yank the motor up enough (without disconnecting the trans) to slide the oil pan out from underneath?
Matt Patton
RIP Jason Harrill 6-12-06: Died doing what he loved
Matt Patton
Not For Nothing But Twice Over The Years Ive Come Across The Little Metal Anti Crush Washers In The V Cover Gaskets Find There Way Into The Oil Pump And Locked It Up Twisting The Oil Pump Shaft Just A Thought
Damn... that blows. Well I know my VC gaskets don't have the anti crush "rings" in them.
If I can remove the pan without removing the motor completely off the tranny and out of the bay I won't hesistate to swap in a new OP.
Matt Patton
Matt Patton
I would try to turn it be hand first. I had afeeling form the start you may had dropped the shaft or something. You could drop the kmember and suspension to get access to the oil pan.
I told you it was the shady between 8:11 and 8:17.
You can lift the motor up high enough in the car to get the pan off and do the pump.
Matt Patton
Matt Patton
I might be able to swing by and lend you a hand if I don't go into work tomorrow.
Do you have an engine hoist? It'd be alot easier to crank the motor up instead of dropping the suspension and K-member.
Steve B almost knew all about that.
6187 126th Ave North
Largo fl 33773
MV#72427
(727)535-6905 - Shaun
Largo fl 33773
MV#72427
