Sudden NO OIL pressure
Old Oct 17, 2007 | 03:08 AM
  #21 (permalink)
Steve B's Avatar
brings his heater.
^true story.
you better have a serious drill for priming
Old Oct 17, 2007 | 03:55 AM
  #22 (permalink)
91Notch's Avatar
Is workin on his car
Yup samething happened to me. Locked up oil pumps are somewhat common in Ford's. Hope that bottom end is still ok.
Old Oct 17, 2007 | 07:44 AM
  #23 (permalink)
Duceanahalf's Avatar
is doing your girlfriend
Matt, I've got that big ass hoist at the shop that you can use, you just need to be able to transport it
Old Oct 17, 2007 | 07:56 AM
  #24 (permalink)
SmokinS13SR20's Avatar
That ginger...
Originally Posted by Duceanahalf
You can lift the motor up high enough in the car to get the pan off and do the pump.
Can you? I was wondering about this, I think I'm going to do my rod bearings the hard way
Good luck man
Old Oct 17, 2007 | 08:07 AM
  #25 (permalink)
$hawn's Avatar
lives in a glass house
good luck with that
Old Oct 17, 2007 | 08:18 AM
  #26 (permalink)
91Notch's Avatar
Originally Posted by $hawn
good luck with that
If its a stock oil pan it can be done. Its tricky though. Drop the pan enough to get to the pick up tube and oil pump. Unbolt them and let them drop into the pan. Unbolt the motor mounts raise the motor. Now here is the trick unbolt the four 15mm bolts on the back of the k member. Unbolt and remove the rearward 18mm k member bolts both passenger and driver sides and remove them. Lossen the front 18mm bolts (both sides of course) of the k member leave them in just lossen them leave the struts bolted up. Stick a pry bar and swing the k member foward and work the pan out.Now we do this all the time here at the shop but we have a lift. Its gonna be a pain doing it on your back. The hard part is putting the pump back in and getting the shaft lined up but there is a trick to that too. There is a way to drop it in from the top.
Old Oct 17, 2007 | 01:06 PM
  #27 (permalink)
SVT1996Cobra's Avatar
What?
why even take the dizzy out??? No big deal to remove the lower intake with the dizzy still in....
Old Oct 17, 2007 | 01:22 PM
  #28 (permalink)
TurboRanger91's Avatar
it's always something
true. and not just the 302's. i've had that happen with two seperate 2.3 motors... one n/a and one turbo.
91 ranger, 88 tc 2.3 turbo, stroked, bored, 5.5" crower connecting rods, wiseco 8.0:1 dished pistons, total seal .030 rings, fully ported iron big valve head, racer walsh turbo roller cam, bobs log, holset wh1c, fmic, full 3" exhaust. not really a whole lot left to do.
93 explorer 4x4
Old Oct 17, 2007 | 02:25 PM
  #29 (permalink)
Matt the Pilot's Avatar
ZAP yo dumb ass!!!!
I was told that these shafts tend to twist up on strong motors and the chances are the pump is fine. So I'm going to attempt to install a new shaft through the dist hole with a magnet and some other type of ingenuity I may come up with. If I get the shaft in the pump I'll test it to see how it works. I just don't want to accept the fact that the pump is gone (because I don't want ot have to swap the bitch.)
Matt Patton
RIP Jason Harrill 6-12-06: Died doing what he loved
Old Oct 17, 2007 | 02:32 PM
  #30 (permalink)
$hawn's Avatar
dont get your hopes up...lol
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
