Anybody had this problem?
Old Feb 17, 2005 | 03:25 AM
GB's Avatar
GB
Great Cornholio
Dumb question but what does TPS stand for?
SLEEPER
Old Feb 17, 2005 | 06:09 AM
Strokd85's Avatar
Daddy-O
Throttle Position Sensor
I am your penalty.....
Old Feb 17, 2005 | 06:22 AM
GB's Avatar
GB
Great Cornholio
Appreciate it.
SLEEPER
Old Feb 17, 2005 | 10:38 AM
LaserCobra's Avatar
I need a helmet.
How To Adjust TPS
"Muscle Mustangs & Fast Fords"
April 1993
The throttle position sensor is one of those things that falls into the category of "computer stuff" that makes a big difference and is easy to deal with, but average people like us would never know about. Without the proper adjustment, the throttle position sensor (TPS) will give the computer a false reading as to the exact throttle opening. A false reading will limit wide open throttle performance (something we definitely don't want). A voltage reading must be taken using a digital volt/ohmmeter (DVOM) with the Key On/Engine Off and with the Key On/Engine Running. A Radio Shack DVOM, part No. 22-185A, works well for this job.
The TPS is located directly on top of the throttle body and is adjusted by loosening the two phillips mounting screws and swiveling the sensor until the highest reading is found. It may be necessary to elongate the holes with a small file to achieve the desired reading.
The spec range for Key On is from .88 to 1.0 volt; shoot for the .97 to .99 volt. With the engine running, the voltage should be no higher than 1.05 volts.
Incorrect Throttle Position Sensor (TPS) voltage will result in reduced performance. The best way to take a TPS voltage reading is by using two safety pins through the wires coming from the sensor. The positive lead is attached to the green wire, while the negative goes to the black wire. Always ground the meter through the sensor's black wire. This gives a direct, and more accurate ground into the computer.
SOLD 6-17-06
'01 Silver Cobra #2709
Procharger P1SC w/10# pulley, 3 core IC, Bassani OR X, Steeda catback, 42# injectors, Lightning 80mm MAF, Tri-Ax, Fat Knob, Battery in da' trunk, JMS Tune 432rwhp / 390rwtq 12.54 @ 115 on street radials
SOLD 6-13-03
'98 Laser Red Cobra #634 of 5174
UPR Power Pipe, BBK off-road H, Flowmasters, 4.10 gears, battery relocated to da' trunk, rear seat delete, Cobra R 17x9 rims with Nitto 315's out back, shaved door locks, 13.35 @105
Old Feb 17, 2005 | 10:45 AM
GB's Avatar
GB
Great Cornholio
I appreciate the good info. We're putting a new speedo cable on next week so I'll check that out as well.
SLEEPER
TaMpAToNy69
Mar 23, 2004 06:05 AM
Preludesitdriver
Dec 13, 2003 08:48 AM
John
Jan 14, 2003 10:56 PM
chino5149
Aug 30, 2002 03:50 PM
