Fuse box diagrams 2018, 2019 Gharger
Old Apr 15, 2020 | 03:42 PM
Default Fuse box diagrams 2018, 2019 Gharger
2018, 2019
Advertisements
Engine Compartment
Assignment of fuses in the Front PDC (201 Cavity Cartridge Fuse Mini-Fuse Description 1 - - Fuse - Spare 2 40 Amp Green - Radiator Fan #1 - (Non 6.2L Supercharged) 3 50 Amp Red - Electric Power Steering #1 - If Equipped 4 30 Amp Pink - Starter 5 40 Amp Green - Anti Lock Brake 6 30 Amp Pink - Anti Lock Brake 7 20 Amp Blue - Police Ignition Run / ACC #1 8 50 Amp Red / 20 Amp Blue - Radiator Fan (6.2L Supercharged) / Police Ignition Run / ACC # 2 9 - 20 Amp Yellow All-Wheel Drive Module - If Equipped 10 - 10 Amp Red Intrusion MOD (300) - If Equipped / Under Hood Lamp - Police 11 - 20 Amp Yellow Horns 12 - 10 Amp Red Air Conditioning Clutch 13 - - Fuse - Spare 14 - - Fuse - Spare 15 - 20 Amp Yellow Left HID - If Equipped 16 - 20 Amp Yellow Right HID - If Equipped 18 50 Amp Red - Radiator Fan - (Non 6.2L Supercharged) 19 50 Amp Red - Electric Power Steering #2 - If Equipped 20 30 Amp Pink - Wiper Motor 21 30 Amp Pink 20 Amp Blue - Police - Headlamp Washers - If Equipped Police Bat Feed #2 22 40 Amp Green / 20 Amp Blue - Police - Engine Cooling Pump (6.2L Supercharged) / Police Bat Feed # 3 23 20 Amp Blue - Police Bat Feed # 1 24 50 Amp Red / 20 Amp Blue - Radiator Fan (6.2L Supercharged) / Police Ignition Run/ACC Feed # 3 28 - - Fuse - Spare 29 - 15 Amp Blue Transmission Control Module (Challenger/ Charger Police) / Electronic Shift Module (Challenger) 30 - - Fuse - Spare 31 - 25 Amp Clear Engine Module 32 - - Fuse - Spare 33 - - Fuse - Spare 34 - 25 Amp Clear Powertrain #1 35 - 20 Amp Yellow Powertrain #2 36 - 10 Amp Red Anti-Lock Brake Module 37 - 10 Amp Red Engine Controller / Rad Fan Relays (Charger/300) / Electric Power Steering Module (Charger/300) / 5-Speed TCM 38 - 10 Amp Red Airbag Module 39 - 10 Amp Red EPS (Challenger) / EHPS (Police) / AC Clutch Relay / Vacuum Pump Relay / Rad Fan Relays (Challenger) 48 - 10 Amp Red AWD Module/Front Axle Disconnect - If Equipped 49 - - Fuse - Spare 50 - - Fuse - Spare 51 - 20 Amp Yellow Vacuum Pump 52 - 5 Amp Tan Adaptive Cruise - If Equipped 53 - - Fuse - SpareAdvertisements
Trunk
Assignment of fuses in the Rear PDC (201 Cavity Cartridge Fuse Mini-Fuse Description 2 60 Amp Yellow - Front PDC Feed #1 3 - - Fuse - Spare 4 60 Amp Yellow - Front PDC Feed #2 5 30 Amp Pink 20 Amp Blue - Police - Sunroof/Dome Lamp - Police 6 40 Amp Green - Exterior Lighting #1 7 40 Amp Green - Exterior Lighting #2 8 30 Amp Pink - Interior Lighting 9 40 Amp Green - Power Locks 10 30 Amp Pink - Driver Door Control Module 11 30 Amp Pink - Passenger Door Control Module 12 - 20 Amp Yellow Dual USB Center Console Rear/Cigar Lighter IP -If Equipped 15 40 Amp Green - HVAC Blower 16 20 Amp Blue - Left Spot Lamp - Police 17 20 Amp Blue - Right Spot Lamp - Police 18 30 Amp Pink - Mod Network Interface - Police 19 - - Fuse - Spare 20 - - Fuse - Spare 21 30 Amp Pink - Fuel Pump (Non 6.2L SRT Demon) 22 - 5 Amp Tan Cyber Gateway Mod 23 - 10 Amp Red Fuel Door/ Diagnostic Port 24 - 10 Amp Red Integrated Center Stack 25 - 10 Amp Red Tire Pressure Monitor 26 - 15 Amp Blue Cygnus Transmission Module (Charger/300) / Electronic Shift Module (Charger/300) 27 - 25 Amp Clear Amplifier - If Equipped 31 - 25 Amp Breaker Power Seats - If Equipped 32 - 15 Amp Blue HVAC Module/Cluster 33 - 15 Amp Blue Ignition Switch/RF Hub Module/ Steering Column Lock (300) - If Equipped 34 - 10 Amp Red Steering Column Module/Clock (300) 35 - 5 Amp Tan Battery Sensor 36 - 15 Amp Blue Electronic Exhaust Valve - If Equipped 37 - 20 Amp Yellow Radio 38 - 20 Amp Yellow Power Outlet Inside Arm Rest/Console Media Hub 40 30 Amp Pink - Fuel Pump (6.2L SRT Demon - If Equipped) 41 30 Amp Pink - Fuel Pump (6.2L SRT Demon - If Equipped) 42 30 Amp Pink - Rear Defrost 43 - 20 Amp Yellow Comfort Seat And Steering Wheel Module (Heated Steering Wheel/RR Heated Seats) 44 - 10 Amp Red Park Assist / Blind Spot / Rear View Camera 45 - 15 Amp Blue Cluster / Rearview Mirror / Compass (Charger/300) / Humidity Sensor / Forward Facing Camera (Lane Departure) / Cyber Gateway 46 - - Fuse - Spare 47 - 10 Amp Red Adaptive Front Lighting / Day Time Running Lamps -If Equipped 48 - 20 Amp Yellow Active Suspension - (6.4L / 6.2L) 49 - - Fuse - Spare 50 - - Fuse - Spare 51 - 20 Amp Yellow Front Heated / Vented Seats - If Equipped 52 - 10 Amp Red Heated Cupholders/Rear Heated Seat Switches -If Equipped 53 - 10 Amp Red HVAC Module/In Vehicle Temperature Sensor 54 - - Fuse - Spare 55 - - Fuse - Spare 56 - - Fuse - Spare 57 - - Fuse - Spare 58 - 10 Amp Red Airbag Module 59 - 20 Amp Yellow Adjustable Pedals - Police 60 - - Fuse - Spare 61 - - Fuse - Spare 62 - - Fuse - Spare 63 - - Fuse - Spare 64 - 25 Amp Breaker Rear Windows (Charger/300) 65 - 10 Amp Red Airbag Module 66 - - Fuse - Spare 67 - 10 Amp Red Rain and Light Sensor / Sunroof / Inside RR View Mirror / Police Run Acc Relay 68 - 10 Amp Red Dual USB Power Outlet - R/A Sense (Charger/300) Rear Sunshade (Charger/300) RR USB Timer 69 - - Fuse - Spare 70 - - Fuse - Spare
Apr 15, 2020 03:40 PM
Apr 15, 2020 03:37 PM
Apr 15, 2020 03:32 PM
Apr 15, 2020 03:29 PM
