Fuse box diagrams 2015 Gharger
Old Apr 15, 2020 | 03:37 PM
Default Fuse box diagrams 2015 Gharger
Engine Compartment
Assignment of fuses in the Front PDC (2015) Cavity Cartridge Fuse Mini-Fuse Description 1 - - Fuse - Spare 2 40 Amp Green - Radiator Fan #1 - If Equipped 3 50 Amp Red — Power Steering #1 / Radiator Fan (6.2L Supercharged) - If Equipped 4 30 Amp Pink - Starter 5 40 Amp Green - Electronic Stability Control 6 30 Amp Pink - Electronic Stability Control 7 - - Fuse - Spare 8 20 Amp Blue - Police Ignition Run / ACC # 2 9 - 20 Amp Yellow All-Wheel Drive Module - If Equipped 10 — 10 Amp Red Security - If Equipped / Under hood Lamp - Police 11 - 20 Amp Yellow Horns 12 - 10 Amp Red Air Conditioning Clutch 13 - - Fuse - Spare 14 - - Fuse - Spare 15 - 20 Amp Yellow Left HID - If Equipped 16 - 20 Amp Yellow Right HID - If Equipped 18 40 Amp Green - Radiator Fan #2 - If Equipped 19 50 Amp Red — Power Steering #2 / Radiator Fan (6.2L Supercharged) 20 30 Amp Pink - Wiper Motor 21 20 Amp Blue — Headlamp Washers - If Equipped / Police Feed 22 40 Amp Green / 20 Amp Blue - Police - Engine Cooling Pump (6.2L Supercharged) / Police Bat Feed # 3 - If Equipped 23 20 Amp Blue - Police Bat Feed # 1 - If Equipped 24 20 Amp Blue - Police Bat Feed # 3 - If Equipped 28 - - Fuse - Spare 29 - 15 Amp Blue Transmission Control Module (LA/LD Police) 30 - - Fuse - Spare 31 - 25 Amp Clear Engine Module 32 - - Fuse - Spare 33 - - Fuse - Spare 34 - 25 Amp Clear Powertrain #1 35 - 20 Amp Yellow Powertrain #2 36 - 10 Amp Red Anti-Lock Brake Module 37 — 10 Amp Red Engine Controller/Rad Fan Relays - If Equipped 38 - 10 Amp Red Airbag Module 39 - 10 Amp Red Power Steering Module/AC Clutch Relay 48 - 10 Amp Red AWD Module/Front Axle Disconnect (LX) / Adaptive Cruise (LA) - If Equipped 49 - - Fuse - Spare 50 - - Fuse - Spare 51 - 20 Amp Yellow Vacuum Pump 52 - 10 Amp Red Adaptive Cruise (LD/LX) - If Equipped 53 - - Fuse - SpareAdvertisements
Trunk
Assignment of fuses in the Rear PDC (2015) Cavity Cartridge Fuse Mini-Fuse Description 2 60 Amp Yellow — Front PDC Feed #1 3 — — Fuse - Spare 4 60 Amp Yellow — Front PDC Feed #2 5 30 Amp Pink — Sunroof / Dome Lamp -Police 6 40 Amp Green — Exterior Lighting #1 7 40 Amp Green — Exterior Lighting #2 8 30 Amp Pink — Interior Lighting 9 40 Amp Green — Power Locks 10 30 Amp Pink — Driver Door Control Module 11 30 Amp Pink — Passenger Door Control Module 12
20 Amp Yellow Dual USB Center Console Rear/Cigar Lighter IP - If Equipped 15 40 Amp Green — HVAC Blower 16 20 Amp Blue — Left Spot Lamp - Police 17 — — Fuse - Spare 18 30 Amp Pink — Mod Network Interface -Police 19 — — Fuse — Spare 20 — — Fuse — Spare 21 30 Amp Pink (6.2L Supercharged) 25 Amp Clear (LD STD)
Fuel Pump (6.2L Supercharged) Fuel Pump (LD STD) 22
20 Amp Yellow - Police 10 Amp Red - LA Right Spot Lamp - Police Integrated Center Stack -LA 23 — 10 Amp Red Fuel Door/Diagnostic Port 24 — 15 Amp Blue Integrated Center Stack -LD/LX 25 — 10 Amp Red Tire Pressure Monitor 26
15 Amp Blue - LD/LX 25 Amp Clear - LA 30 Amp Green - LA 6.2L Supercharged Transmission / Electronic Shift Module (LD/LX) Fuel Pump (LA) Fuel Pump (LA 6.2L Supercharged) 27 — 25 Amp Clear Amplifier - If Equipped 31 — 25 Amp Breaker Power Seats 32 — 15 Amp Blue HVAC Module/Cluster 33
15 Amp Blue Ignition Switch/RF hub Module/Steering Column Lock-LX If Equipped 34
10 Amp Red Steering Column Module/Clock /Spare -Police 35 — 5 Amp Tan Battery Sensor 36 — 15 Amp Blue Electronic Exhaust Valve - If Equipped 37 — 20 Amp Yellow Radio 38
15 Amp Blue - LD/LX 20 Amp Yellow - LA Console Power Outlet/ Console Media Hub (LD/ LX) Power Outlet Inside Arm Rest/Console Media Hub (LA) 40 — — Fuse — Spare 41 — — Fuse — Spare 42 30 Amp Pink — Rear Defrost 43 — 20 Amp Yellow Rear Heated Seats/ Steering Wheel Module 44
10 Amp Red Park Assist / Blind Spot / Rear View Camera 45
15 Amp Blue Cluster / Rearview Mirror / Compass(LDLX)/ Humidity Sensor 46 — — Fuse — Spare 47
10 Amp Red Adaptive Front Lighting / Auto High BEAM / Day Time Running Lamps- If Equipped 48 — 20 Amp Yellow Active Suspension - SRT 49 — — Fuse — Spare 50 — — Fuse — Spare 51 — 20 Amp Yellow Front Heated Seats - If Equipped 52
10 Amp Red Heated Cupholders/Rear Heated Seat Switches - If Equipped 53 — 10 Amp Red HVAC Module/In Car Temperature Sensor 54 — 10 Amp Red Airbag Module (LA) 55 — — Fuse — Spare 56 — — Fuse — Spare 57 — — Fuse — Spare 58 — 10 Amp Red Airbag Module (LD/LX) 59 — 20 Amp Yellow Adjustable Pedals - Police 60 — 5 Amp Tan Heated Washer Nozzles (LD) 61
20 Amp Yellow Cigar Lighter (LA) - If Equipped 62 — — Fuse — Spare 63 — — Fuse — Spare 64 — 25 Amp Breaker Rear Windows (LD/LX) 65 — 10 Amp Red Airbag Module 66 — — Fuse — Spare 67 — 10 Amp Red Rain and Light Sensor/ Sunroof 68
10 Amp Red Dual USB Power Outlet -R/A Sense (LD/LX) Rear Sunshade (LD/LX) 69 — — Fuse — Spare 70 — — Fuse — Spare
Apr 15, 2020 03:42 PM
Apr 15, 2020 03:40 PM
Apr 15, 2020 03:37 PM
Apr 15, 2020 03:32 PM
Apr 15, 2020 03:29 PM
