Fuse box diagrams 2013, 2014 Gharger
2013, 2014
Engine Compartment
Assignment of fuses in the Front PDC (2013, 2014) Cavity Cartridge Fuse Mini-Fuse Description 1 - - Fuse - Spare 2 40 Amp Green - Radiator Fan #1 3 50 Amp Red - Power Steering #1 4 30 Amp Pink - Starter 5 40 Amp Green - Anti-Lock Brakes 6 25 Amp Natural - Anti-Lock Brakes 7 - - Fuse - Spare 8 - - Fuse - Spare 9 - 20 Amp Yellow All-Wheel Drive Module - If Equipped 10 - 10 Amp Red Security 11 - 20 Amp Yellow Horns 12 - 10 Amp Red Air Conditioning Clutch 13 - - Fuse - Spare 14 - - Fuse - Spare 15 - 25 Amp Natural Transmission 16 - - Fuse - Spare 18 50 Amp Red - Radiator Fan #2 19 50 Amp Red - Power Steering #2 20 30 Amp Pink - Wiper Motor 21 30 Amp Pink - Headlamp Washers 22 - - Fuse - Spare 23 - - Fuse - Spare 24 - - Fuse - Spare 28 - 25 Amp Natural Fuel Pump 29 - 15 Amp Blue Transmission Shifter 30 - - Fuse - Spare 31 - 25 Amp Natural Engine Module 32 - - Fuse - Spare 33 - - Fuse - Spare 34 - 25 Amp Natural Powertrain #1 35 - 20 Amp Yellow Powertrain #2 36 - 10 Amp Red Anti-Lock Brake Module 37 - 10 Amp Red Engine Controller/Rad Fan Relays 38 - 10 Amp Red Airbag Module 39 - 10 Amp Red Power Steering Module/ AC Clutch Relay 48 - 10 Amp Red AWD Module/Front Axle Disconnect 49 - - Fuse - Spare 50 - - Fuse - Spare 51 - 20 Amp Yellow Vacuum Pump 52 - - Fuse - Spare 53 - - Fuse - Spare
Trunk
Assignment of fuses in the Rear PDC (2013, 2014) Cavity Cartridge Fuse Mini-Fuse Description 2 60 Amp Yellow — Front PDC Feed #1 3 — — Fuse - Spare 4 60 Amp Yellow — Front PDC Feed #2 5 30 Amp Pink — Sunroof 6 40 Amp Green — Exterior Lighting #1 7 40 Amp Green — Exterior Lighting #2 8 30 Amp Pink — Interior Lighting/Washer Pump 9 30 Amp Pink — Power Locks 10 30 Amp Pink — Driver Door 11 30 Amp Pink — Passenger Door 12
20 Amp Yellow Cigar Lighters, Instrument Panel & Power Outlet Console Rear 15 40 Amp Green — HVAC Blower 16 — — Fuse — Spare 17 — — Fuse — Spare 18 — — Fuse — Spare 19 — — Fuse — Spare 20 — — Fuse — Spare 21 — — Fuse — Spare 22 — — Fuse — Spare 23 — 10 Amp Red Fuel Door/Diagnostic Port 24 — 15 Amp Blue Radio Screen 25 — 10 Amp Red Tire Pressure Monitor 26 — — Fuse — Spare 27 — 25 Amp Natural Amplifier 31 — 25 Amp Natural Power Seats 32 — 15 Amp Blue HVAC Module/Cluster 33
15 Amp Blue Ignition Switch/Wireless Module 34 — 10 Amp Red Steering Column Module/Qock 35 — 10 Amp Red Battery Sensor 36 — — Fuse — Spare 37 — 15 Amp Blue Radio 38 — 20 Amp Yellow Power Outlet Inside Arm Rest 40 — — Fuse — Spare 41 — — Fuse — Spare 42 30 Amp Pink — Rear Defrost 43 — 25 Amp Natural Rear Heated Seats/ Steering Wheel 44 — 10 Amp Red Park Assist/Blind Spot/ Camera 45 — 15 Amp Blue Cluster/Rearview M i rror /Compass 46 — 10 Amp Red Adaptive Cruise Control 47 — 10 Amp Red Adaptive Front Lighting 48 — 20 Amp Yellow Active Suspension 49 — — Fuse — Spare 50 — — Fuse — Spare 51 — 20 Amp Yellow Front Heated Seats 52 — 10 Amp Red Heated Cupholders/Rear Heated Seat Switches 53 — 10 Amp Red HVAC Module/In Car Temperature Sensor 54 — — Fuse — Spare 55 — — Fuse — Spare 56 — — Fuse — Spare 57 — — Fuse — Spare 58 — 10 Amp Red Airbag Module 59 — — Fuse — Spare 60 — — Fuse — Spare 61 — — Fuse — Spare 62 — — Fuse — Spare 63 — — Fuse — Spare 64 — 25 Amp Natural Rear Windows 65 — 10 Amp Red Airbag Module 66 — — Fuse — Spare 67 — 15 Amp Blue Run Sense 68 — 15 Amp Blue Illumination/Rear Sunshade 69 — — Fuse — Spare 70 — — Fuse — Spare
Apr 15, 2020 03:42 PM
Apr 15, 2020 03:40 PM
Apr 15, 2020 03:37 PM
Apr 15, 2020 03:29 PM
