Fuse box diagrams 2011, 2012 Gharger
Old Apr 15, 2020 | 03:29 PM
Default Fuse box diagrams 2011, 2012 Gharger
2011, 2012
Engine Compartment
Assignment of fuses in the Front PDC (2011, 2012) Cavity Cartridge Fuse Mini-Fuse Description 1 — — Fuse - Spare 2 40 Amp Green — Radiator Fan #1 3 50 Amp Red — Power Steering #1 4 30 Amp Pink — Starter 5 40 Amp Green — Anti-Lock Brakes 6 — — Fuse - Spare 7 — — Fuse - Spare 8 — — Fuse - Spare 9 — 20 Amp Yellow All-Wheel Drive Module - If Equipped 10 — 10 Amp Red Security 11 — 20 Amp Yellow Horns 12 — 10 Amp Red Air Conditioning Clutch 13 — — Fuse - Spare 14 — 25 Amp Natural Anti-Lock Brakes 15 — 25 Amp Natural Transmission 16 — — Fuse - Spare 18 50 Amp Red — Radiator Fan #2 19 50 Amp Red — Power Steering #2 20 30 Amp Pink — Wiper Motor 21 30 Amp Pink — Headlamp Washers 22 — — Fuse - Spare 23 — — Fuse - Spare 24 — — Fuse - Spare 28 — 25 Amp Natural Fuel Pump 29 — 15 Amp Blue Transmission Shifter 30 — — Fuse - Spare 31 — 25 Amp Natural Engine Module 32 — — Fuse - Spare 33 — — Fuse - Spare 34 — 25 Amp Natural Powertrain #1 35 — 20 Amp Yellow Powertrain #2 36 — 10 Amp Red Anti-Lock Brake Module 37 — 10 Amp Red Engine Controller/ Rad Fan Relays 38 — 10 Amp Red Airbag Module 39
10 Amp Red Power Steering Module/AC Clutch Relay 48 — 10 Amp Red AWD Module/Front Axle Disconnect 49 — — Fuse - Spare 50 — — Fuse - Spare 51 — 20 Amp Yellow Vacuum Pump 52 — — Fuse - Spare 53 — — Fuse - Spare
Trunk
Assignment of fuses in the Rear PDC (2011, 2012) Cavity Cartridge Fuse Mini-Fuse Description 2 60 Amp Yellow — Front PDC Feed #1 3 — — Fuse - Spare 4 60 Amp Yellow — Front PDC Feed #2 5 30 Amp Pink — Sunroof 6 40 Amp Green — Exterior Lighting #1 7 40 Amp Green — Exterior Lighting #2 8 30 Amp Pink — Interior Lighting/ Washer Pump 9 30 Amp Pink — Power Locks 10 30 Amp Pink — Driver Door 11 30 Amp Pink — Passenger Door 12
20 Amp Yellow Cigar Lighters, Instrument Panel & Power Outlet Console Rear 15 40 Amp Green — HVAC Blower 16 — — Fuse — Spare 17 — — Fuse — Spare 18 — — Fuse — Spare 19 — — Fuse — Spare 20 — — Fuse — Spare 21 — — Fuse — Spare 22 — — Fuse — Spare 23 — 10 Amp Red Fuel Door/Diagnostic Port 24 — 15 Amp Blue Radio Screen 25 — 10 Amp Red Tire Pressure Monitor 26 — — Fuse — Spare 27 — 25 Amp Natural Amplifier 31 — 25 Amp Natural Power Seats 32 — 15 Amp Blue HVAC Module/ Cluster 33 — 15 Amp Blue Ignition Switch/ Wireless Module 34 — 10 Amp Red Steering Column Module/Clock 35 — 10 Amp Red Battery Sensor 36 — — Fuse — Spare 37 — 15 Amp Blue Radio 38 — 20 Amp Yellow Power Outlet Inside Arm Rest 40 — — Fuse — Spare 41 — — Fuse — Spare 42 30 Amp Pink — Rear Defrost 43 — 25 Amp Natural Rear Heated Seats/ Steering Wheel 44 — 10 Amp Red Park Assist/Blind Spot/Camera 45 — 15 Amp Blue Cluster/Rearview Mirror/Compass 46 — 10 Amp Red Adaptive Cruise Control 47 — 10 Amp Red Adaptive Front Lighting 48 — 20 Amp Yellow Active Suspension 49 — — Fuse — Spare 50 — — Fuse — Spare 51 — 20 Amp Yellow Front Heated Seats 52 — 10 Amp Red Heated Cupholders/ Rear Heated Seat Switches 53
10 Amp Red HVAC Module/In Car Temperature Sensor 54 — — Fuse — Spare 55 — — Fuse — Spare 56 — — Fuse — Spare 57 — — Fuse — Spare 58 — 10 Amp Red Airbag Module 59 — — Fuse — Spare 60 — — Fuse — Spare 61 — — Fuse — Spare 62 — — Fuse — Spare 63 — — Fuse — Spare 64 — 25 Amp Natural Rear Windows 65 — 10 Amp Red Airbag Module 66 — — Fuse — Spare 67 — 15 Amp Blue Run Sense 68 — 15 Amp Blue Illumination/Rear Sunshade 69 — — Fuse — Spare 70 — — Fuse — Spare
Apr 15, 2020 03:42 PM
Apr 15, 2020 03:40 PM
Apr 15, 2020 03:37 PM
Apr 15, 2020 03:32 PM
