Fuse box diagrams 2016 Gharger
Old Apr 15, 2020 | 03:37 PM
Default Fuse box diagrams 2016 Gharger
2016
Advertisements
Engine Compartment
Assignment of fuses in the Front PDC (2016) Cavity Cartridge Fuse Mini-Fuse Description 1 - - Fuse - Spare 2 40 Amp Green — Radiator Fan #1 -(Non 6.2L Supercharged) 3 50 Amp Red
Electric Power Steering #1 -If Equipped / Radiator Fan (6.2L Supercharged) - If Equipped 4 30 Amp Pink - Starter 5 40 Amp Green - Electronic Stability Control 6 30 Amp Pink - Electronic Stability Control 7 20 Amp Blue - Police Ignition Run / ACC #1 8 20 Amp Blue - Police Ignition Run / ACC # 2 9 - 20 Amp Yellow All-Wheel Drive Module - If Equipped 10
10 Amp Red Security - If Equipped / Under hood Lamp - Police 11 - 20 Amp Yellow Horns 12 - 10 Amp Red Air Conditioning Clutch 13 - - Fuse - Spare 14 - - Fuse - Spare 15 - 20 Amp Yellow Left HID - If Equipped 16 - 20 Amp Yellow Right HID - If Equipped 18 50 Amp Red " Radiator Fan #2 -(Non 6.2L Supercharged) 19 50 Amp Red
Electric Power Steering #2 -If Equipped / Radiator Fan (6.2L Supercharged) 20 30 Amp Pink - Wiper Motor 21 30 Amp Pink 20 Amp Blue -Police
Headlamp Washers - If Equipped Police Bat Feed #2 22 40 Amp Green / 20 Amp Blue -Police
Engine Cooling Pump (6.2L Supercharged) / Police Bat Feed # 3 23 20 Amp Blue - Police Bat Feed # 1 24 20 Amp Blue - Police Ignition Run/ACC Feed # 3 28 - - Fuse - Spare 29
15 Amp Blue Transmission Control Module (Challenger/Charger Police) / Electronic Shift Module (Challenger) 30 - - Fuse - Spare 31 - 25 Amp Clear Engine Module 32 - - Fuse - Spare 33 - - Fuse - Spare 34 - 25 Amp Clear Powertrain #1 35 - 20 Amp Yellow Powertrain #2 36 - 10 Amp Red Anti-Lock Brake Module 37
10 Amp Red Engine Controller / Rad Fan Relays (Charger/300) / Electric Power Steering Module (Charger/300) / Fuel Pump Relay (Charger/300) / 5-Speed 38 - 10 Amp Red Airbag Module 39
10 Amp Red EPS (Challenger) / EHPS (Police)/AC Clutch Relay / Vacuum Pump Relay / Fuel Pump Relay (Challenger) / Rad Fan Relays (Challenger) 48
10 Amp Red AWD Module (Charger/300) / Front Axle Disconnect (Charger/300) / Adaptive Cruise (Challenger) - If Equipped 49 - - Fuse - Spare 50 - - Fuse - Spare 51 - 20 Amp Yellow Vacuum Pump 52 — 5 Amp Tan Adaptive Cruise (Charger/300) -If Equipped 53 - - Fuse - SpareAdvertisements
Trunk
Assignment of fuses in the Rear PDC (2016) Cavity Cartridge Fuse Mini-Fuse Description 2 60 Amp Yellow - Front PDC Feed #1 3 - - Fuse - Spare 4 60 Amp Yellow - Front PDC Feed #2 5 30 Amp Fink 20 Amp Blue - Police
Sunroof/Dome Lamp -Police 6 40 Amp Green - Exterior Lighting #1 7 40 Amp Green - Exterior Lighting #2 8 30 Amp Fink - Interior Lighting 9 40 Amp Green - Power Locks 10 30 Amp Fink — Driver Door Control Module 11 30 Amp Fink — Passenger Door Control Module 12
20 Amp Yellow Dual USB Center Console Rear/Cigar Lighter IP -If Equipped 15 40 Amp Green - HVAC Blower 16 20 Amp Blue - Left Spot Lamp - Police 17 - - Fuse - Spare 18 30 Amp Fink — Mod Network Interface -Police 19 - - Fuse - Spare 20 - - Fuse - Spare 21 30 Amp Fink - Fuel Pump 22 - 20 Amp Yellow - Police Right Spot Lamp - Police 23 — 10 Amp Red Fuel Door/Diagnostic Port 24 - 10 Amp Red Integrated Center Stack 25 - 10 Amp Red Tire Pressure Monitor 26
15 Amp Blue Cygnus Transmission Module (Charger/300)/ Electronic Shift Module (Charger/300) 27 - 25 Amp Clear Amplifier - If Equipped 31 — 25 Amp Breaker Power Seats -If Equipped 32 - 15 Amp Blue HVAC Module/Cluster 33
15 Amp Blue Ignition Switch/RF Hub Module/Steering Column Lock (300) -If Equipped 34 — 10 Amp Red Steering Column Module/Clock (300) 35 - 5 Amp Tan Batten- Sensor 36 — 15 Amp Blue Electronic Exhaust Valve - If Equipped 37 - 20 Amp Yellow Radio 38 — 20 Amp Yellow Power Outlet Inside Arm Rest/Console Media Hub 40 - - Fuse - Spare 41 - - Fuse - Spare 42 30 Amp Pink - Rear Defrost 43 — 20 Amp Yellow Comfort Seat And Steering Wheel Module (Heated Steering Wheel/RR Heated Seats) 44 — 10 Amp Red Park Assist / Blind Spot / Rear View Camera 45 — 15 Amp Blue Cluster / Rearview Mirror / Compass (Charger/ 300) / Humidity Sensor 46 — — Fuse - Spare 47 — 10 Amp Red Adaptive Front Lighting / Auto High BEAM / Day Time Running Lamps - If Equipped 48 — 20 Amp Yellow Active Suspension -If Equipped 49 — — Fuse - Spare 50 — — Fuse - Spare 51 — 20 Amp Yellow Front Heated Seats -If Equipped 52 — 10 Amp Red Heated Cupholders/Rear Heated Seat Switches -If Equipped 53 — 10 Amp Red HVAC Module/ln Vehicle Temperature Sensor 54 — - Fuse - Spare 55 — - Fuse - Spare 56 — - Fuse - Spare 57 — - Fuse - Spare 58 — 10 Amp Red Airbag Module 59 — 20 Amp Yellow Adjustable Pedals -Police 60 — 5 Amp Tan Heated Washer Nozzles (Charger) 61 — - Fuse - Spare 62 — - Fuse - Spare 63 — — Fuse - Spare 64 — 25 Amp Breaker Rear Windows (Charger/300) 65 — 10 Amp Red Airbag Module 66 — - Fuse - Spare 67 — 10 Amp Red Rain and Light Sensor / Sunroof / Inside RR View Mirror / Power Outlet Illumination (Center Console) / Police Run Acc Relay 68 — 10 Amp Red Dual USB Power Outlet -R/A Sense (Charger/300) Rear Sunshade (Charger/300) 69 — — Fuse - Spare 70 — — Fuse - Spare
Apr 15, 2020 03:42 PM
Apr 15, 2020 03:40 PM
Apr 15, 2020 03:37 PM
Apr 15, 2020 03:32 PM
Apr 15, 2020 03:29 PM
