Subaru Tech All We'll Drive
data logging
Old Apr 2, 2009 | 01:54 PM
specVmatt's Avatar
400hp club, barely
Default data logging
Well, my cel for the front o2 went away, so i reset the ecu and got the dynamics multiplyer to 1. afr's at cruising are perfect according to my eugo and accessport. 10.0-10.4 at WOT. Car feels so slow, obviously because of that. For some reason when stopped though, the car idle's really low and stalls on occasion. i didnt really drive the car much since i reset the ecu. So i figured it needed to relearn some stuff. I just took it out and did some logging with the accessport. Once I was done, I realized the idle issue is nearly gone. So thats good. I run upstairs to install the accessport manager and plug the accessport in. What do you know, it is not compatible with windows vista 64bit. So once I get a computer with 32bit, ill post up the logs and maybe someone can help figure out what my issue is. sigggggggggggggh.
Coyote
Old Apr 2, 2009 | 02:45 PM
specVmatt's Avatar
400hp club, barely
im no tuner, but nothing seems out of the ordinary. a bit of overboost.. cant be the problem though since the last log showed no overboost but still runs very rich. i thought datalogging showed afr's though.
Coyote
Old Apr 2, 2009 | 02:49 PM
ShockerGT's Avatar
Shake n bake
Run a log for knock
Check your engine grounds
Vaccum leaks
Reset ecu again and reload map
Finally compression test
Other than that, I don't know how to help you.
Old Apr 2, 2009 | 03:51 PM
racer_x's Avatar
vroom psshh.
vista FTL
install a virtual machine:
Microsoft Virtual Machine 2007
Old Apr 2, 2009 | 03:52 PM
racer_x's Avatar
vroom psshh.
engine grounds is an interesting idea...
Old Apr 2, 2009 | 03:57 PM
blacksti's Avatar
DudeMan
data logging isnt going to show afr's under boost... thats what widebands are for unless you hook up your wideband into the data logging
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Apr 2, 2009 | 04:08 PM
specVmatt's Avatar
400hp club, barely
Originally Posted by racer_x
vista FTL
Thanks Frank.
Coyote
Old Apr 2, 2009 | 04:14 PM
ShockerGT's Avatar
Shake n bake
I've read more than once that a loose engine ground could make the car run like crap
Old Apr 2, 2009 | 04:20 PM
racer_x's Avatar
vroom psshh.
+1
Old Apr 2, 2009 | 06:37 PM
specVmatt's Avatar
400hp club, barely
well what do you mean by crap? car feels smooth still, just slower. and its clearly because of the rich conditions. but i will check that as well, thanks.
Coyote
