Subaru Tech All We'll Drive
data logging
Old Apr 2, 2009 | 07:18 PM
ShockerGT's Avatar
Shake n bake
As in it will not drive the way you want it
You could just be used to the power too.
Old Apr 2, 2009 | 07:58 PM
racer_x's Avatar
vroom psshh.
^ I don't think so... there's likely a problem looking at those afrs
Old Apr 2, 2009 | 08:07 PM
blacksti's Avatar
DudeMan
full boost at 4200? isnt that slow for that turbo? if its richer that slows down spool ummm what did it hit full boost at before?
2jz mustang build
https://www.tamparacing.com/forums/g...l-project.html
Old Apr 3, 2009 | 02:46 AM
racer_x's Avatar
vroom psshh.
it is slow for the dom3. I'd have to dig up an old post, but I believe matt said he's been hitting full boost around 4-4200k since he's been tuned. Overly rich could obviously bog him down, but I don't really understand what could have changed so drastically with his car since he got tuned.
Old Apr 3, 2009 | 03:08 AM
specVmatt's Avatar
400hp club, barely
4200 rpm spool is what i've always been at. its a tad bit slower than others, but take into consideration most people have headers and tgv deletes, i dont.
Coyote
Old Apr 3, 2009 | 05:44 AM
I'm Slow's Avatar
I'm Slow
The fact that your afr is 10 under wot is a problem. I would call my tuner
Old Apr 3, 2009 | 06:14 AM
  #17 (permalink)
specVmatt's Avatar
400hp club, barely
does resetting the ecu cause the tune to maybe lose some parameters? should i reflash the tune back onto the ecu?
Coyote
Old Apr 3, 2009 | 06:16 AM
  #18 (permalink)
3gsucks's Avatar
the data on the log does not show any problems that i can see although there is no wideband data. it seems like the turbo is made to spool slow. the duty cycles on the wastegate is pretty low then comes up.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
Old Apr 3, 2009 | 06:17 AM
  #19 (permalink)
3gsucks's Avatar
only if the tune was on cobb on the ram. but it will not lose any rom data
Old Apr 3, 2009 | 06:45 AM
  #20 (permalink)
specVmatt's Avatar
400hp club, barely
would it hurt to reflash the tune?
Coyote
