SS tuning results thread
That blue is tough to read... Is that APS exhaust a full TBE? catless or catted? Also you might want to "test" with the stock air box and a K&N drop in filter. You might get a tad bit MORE performance with the stocker in and the sliencer removed. SS explained to me how the APS intake causes a wave in the A/F table. Has something to do with how high the filer sits in the fender well. You might only be able to use that intake correctly with a pro-tune from SS.
-2006 Subaru WRX Limited
-2009 Chevrolet Cobalt SS
I just had Scott tune mine and all I've got is a DP and an Accessport. Scott says its one of his favorite tunes - you get so much with so little. An increase of about a 100 ft. lbs. of torque at 3200 RPM! It's a huge difference over stock and the increase from the OTS Stage II map to the pro tune is dramatic.
Yep actually the Turbo is fairly easy to remove. Takes some time but i have pulled mine many times for various reasons. The only prob is when it comes to putting the turbo back in. There is an oil line directly underneath and you have to get that pipe to fit back inthe hose. That Hose is pretty rigid so what i always do is take a little mobile 1 and lightly coat the oil line so that it slides in to the hose easier.
04 WRB STI APS stage 2, K&N typhoon, walbro 255, protuned. CAR FORSALE.
It's always a good idea to replace them. You CAN re-use them, but it's not the best thing. The best is to go w/ the copper gaskets, but you can get OEM ones from Mastro, or just order them off the internet.
change the gaskets or you'll end up with exhuast leaks.
its not fun after you spent all that time putting stuff in.
trust me gaskets are not reusable.
6 letters spell it, 5 lifters be ticking on it, 4 cams spinning on it, 3in cutout on it, 2 heads flowing on it, 1 turbo creeping on it, SUBARU.
Osecuroms.org Opensource Stage II 2006 wrx 281 downloads and counting
Pm me about Subaru Tuning
where is the best place to get them quick because i am going to replace them next week. and where do i get the copper ones
:: Crucial Racing Systems - The parts you need for the performance you want
this is what i ordered. They are fast at shipping too. I ordered on monday it came by wednesday.
tomorrow morning i should have no leaks
