Need some help...
Just wondering if someone with a Delta Dash could help me out? I need to get a few reading from my ECU, including what my advance multiplier is set at and my air/fuel ratio at idle.
James -- got a hole of Jarrad at PDX. Without knowing what my ECU is doing he couldn't give me detailed help. He did suggest the possibility of a bad front O2 sensor, but wouldn't that throw a CEL?
Yes, I have looked at my ECU. James said if he had a laptop he'd plug it in and check the readings, so I'm assuming DD has a feature on computer that can check ECU readings.
okey cool because i have heard of people cutting the wire that runs from the ECU to the check engine light.... so the ECU really is telling the light to light up, but.....
it is a orange wire, i think....
Guest
Posts: n/a
yep just get me a laptop to use i can see everything the ecu is doing. if the laptop you bring has wireless internet i can email the logs to PDX to have them look them over. i wonder if i can tell if it is flashed or not with the DD
Originally Posted by mantra1
Balboa:
If you need access to a laptop, let me know.
Guest
Posts: n/a
I'd appreciate it very much if you have a laptop James could use to read my ECU!
Grounding kit is the only thing I've changed. I currently have 89 in there because I always drive like a grandma during the week. Plus $2.75 a gallon is killer. Come friday I'll fill her up with Shell 93.
Thanks so much for helping, I couldn't do it without you!
Guest
Posts: n/a
