Need some help...
anyone have carfax?? this could give you all the past data you could want (nd maybe some you dont) on the vechicle's past....
im sure you can get "un" ecutek'd too, if mastro (or ???) took your ecu and reset it to oem paramters (dropped the 2004 revised mapp). that should eliminate that as a potential issue. if you have to, perhaps overnight it to pdx and hve them reflash it...
as for porting, well, i know nothing there; def. a thing to investigate.....
ese
ese
www.gsxRpaddock.com <---gsxR research, solutions, & support
www.iWSTi.com <---STi research, solutions, & support
www.TOPSPEEDsales.com <---STi premier tuning and performance
I've been talking to Jarrad at PDX. James, Rob, and I are going to check my ECU with James' Delta Dash software and Rob's laptop. BTW Rob, does your LT have Wireless Internet?
James or I will need to e-mail Jarrad the reading we get before any conclusions can be made.
Guest
Posts: n/a
the ecutek license is erased when the other owner put the AP on it. i think the AP has fucked it up. dont worry evan, me and jarrad will get it figured out. we will make it a beast again. i want to see the compression numbers first.
