HELP...ka-t breaking up in mid boost...HELP
Old Dec 9, 2011 | 04:51 AM
Ashy-Larry's Avatar
Congac, bannana bitch
IIRC .25 is the gap you want to target for KAT,i may be wrong but like i said,iirc. Too wide of gap w/too much boost may cause blow out which could be causing your break up.
Try this if boost leak turns out A-OK.
-Julien
Old Dec 9, 2011 | 05:12 AM
David48's Avatar
I <3 usdm
When I was looking into ka-t I believe I read .36 is the proper gap
Potato
shit got all davided up.
Old Dec 9, 2011 | 05:17 AM
David48's Avatar
I <3 usdm
If you need a new filter, I found this on zilvia
NY be clean be safe use a filter buy this one - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum
Potato
Old Dec 9, 2011 | 07:49 AM
KRUKED's Avatar
.....taste the rainbow
.36 is the right gapage, but regardless off the matter, my previous plugs were gapped at the same for right at a year and I never had an issue w/ them. I'm gonna make a trip to Home Depot here in a few and McGyver some shit for a boost leak check.
You know, somebody actually complimented me on my driving today. They left a little note on the windshield, it said 'Parking Fine.'
Old Dec 9, 2011 | 09:29 AM
box240mod's Avatar
tire eater
there is a shop on ulmerton and 49th, darkside performance i think.... they have a shop forum on here. he boost leak checked my old setup and found my leak. took 15 min?
Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com! Visit J1Nracing.com!
Box on FB
Old Dec 9, 2011 | 09:49 AM
omgosh's Avatar
Darkside is gone...shop is still open under a different name. Run by a guy named Seth...good dude. Ive worked with him before.
Old Dec 9, 2011 | 10:37 AM
  #17 (permalink)
Ashy-Larry's Avatar
Okay, cool, then you can rule that out.Like i said, i didnt remember, its been a while since I messed w/kat specific specs and the like. GLWTest, let us know what transpires.
-Julien
Old Dec 9, 2011 | 11:40 AM
  #18 (permalink)
KRUKED's Avatar
I was just over in that area 2 hours ago. Too late though, I already bought a few knickknacks for my tester...hopefully they work out. If not, oops!
Old Dec 9, 2011 | 12:37 PM
  #19 (permalink)
KRUKED's Avatar
Originally Posted by omgosh
Bitches dont know bout the dataloggers CJ. lol
Some people just can't afford 'em
Old Dec 10, 2011 | 05:00 PM
  #20 (permalink)
KRUKED's Avatar
Vacuum/boost leak is the culprit. The gasket in between the plenum and the runners had a blow out. Hopefully that's the only leak. I'll double check again after the gasket has had time to make itself at home. I did a compression of 14psi and after I took off the air hose off, it dropped down to 0psi in a matter of seconds. My rigged up end cap blew off at one point of time and I swear to God, a confettied $50 bill blew out. I was appalled and couldn't believe it!
NGarland
Nissan/Infiniti Tech
9
Sep 16, 2011 06:34 AM
MadeAStinky
Jul 14, 2008 06:18 AM
Jason.
Aug 19, 2007 11:05 PM
Turbo GSR Civic 95
Oct 25, 2004 08:38 AM
Hyper2002
May 12, 2003 04:19 PM
